39,396 Members 1,487,240 Posts
Bit of a Technical Question..
This is a discussion on Bit of a Technical Question.. within the Octavia I forums, part of the Skoda Model Discussion Area category; 52 plate Ocy 1 VRS. On cold start, it has irregular running, and when the Engine warms up, it goes. ...
Old 15-11-2007, 12:49   #1
is chilled out!
youngsyd's Avatar
Members Car: Fabia vRS Black Magic
52 plate Ocy 1 VRS.
Anyone had this before?
Cheers
Blood runs through our veins, thats where all similarities end....
youngsyd is offline
Old 15-11-2007, 12:50   #2
ethos's Avatar
Members Car:
Re: Bit of a Technical Question..
I think it's a pretty common problem if you do a search.
Try unplugging the maf and see if that makes a difference or even cleaning the connector (search cage mod).
When you say is has irregular running, what exactly do you mean?
ethos is offline
Old 15-11-2007, 13:28   #3
Need more power
martziniuk's Avatar
Members Car: octavia VRS
I should think its the secondary air pump. This will start for the first 1-2min when cold then turn off,your car should run ok after.The pump is used to warm the cat up on cold start, for emmisions i believe.
Search the forum there are even instructions on how to rebuild it.
Regards Martin
Turbo back blueflame exhaust ,Forge 007p Dump valve, Ramair filter, Prosport boost gauge, Autobahn88 TIP, Ecu Evolution Remap, FMIC
martziniuk is offline
Old 15-11-2007, 13:43   #4
is chilled out!
youngsyd's Avatar
Erm, kinda running on 3 cylinders, that sort or rough running.
We thought Secondary Air Pump....we have already unplugged airflow, and is still the same too...
youngsyd is offline
Old 15-11-2007, 13:53   #5
Need more power
martziniuk's Avatar
Have you run vag-com for codes?
Regards Martin
Old 15-11-2007, 13:53   #6
ethos's Avatar
Members Car:
Guide for rebuilding the secondary air pump;
Step-by-step guide for repairing the Secondary Air Pump (with pictures) - uk-mkivs
ethos is offline
Similar Threads
bit of a silly question McG MkII Fabia I 13 20-07-2006 19:38
Technical Question re mirror switch yashicamat Fabia I 18 13-05-2006 07:57
Hello! I'm here for technical help jby69 INTRODUCE YOURSELF! First time visitors, say hello here. 4 13-11-2005 17:12
Technical help from myself..part2 Lummox General Car Chat 48 17-02-2005 20:32
Probably Should Be In The 'technical' Inbox But... RickyBoy Maintenance & Performance 3 21-05-2003 21:43
