Bleeding the brakes
This is a discussion on Bleeding the brakes within the Octavia I forums, part of the Skoda Model Discussion Area category; Changed the rear pads on the Octavia the other weekend but had to take the calliper off in the process. ...
Old 30-01-2006, 09:43   #1
Post Bleeding the brakes
Changed the rear pads on the Octavia the other weekend but had to take the calliper off in the process. I wasn't too succesfull bleeding the system, it's ok but not as firm as it should be. What are the brake circuits on the Octavia and what order should the brakes be bled? I see from reading some other posts there is a bleed valve on the master cylinder too, I assume thats bled last?
Regards
nitro_warrior is offline
Old 30-01-2006, 09:57   #2
mbames's Avatar
Default Re: Bleeding the brakes
is there any actual need to bleed the brakes if your just changing pads? I normally just remove the res. cap, push the piston back in gently, slide in new pads and call it quits at that....
mbames is offline
Old 30-01-2006, 14:54   #3
Indeed not but I had to take the calliper off the car as I accidently let the piston go too far and let the seal come off the piston . I couldn't get it back on in situ so took it off the car. Also discovered the pistons screw back in rather than just pushing in.
Old 30-01-2006, 15:48   #4
mbames's Avatar
Arh... my Pug 306 you screwed the pistons in on the rear, but not the fronts.... Dunno what the approved method is, but I used to think that you were meant to do them diagonally. Maybe say it is time to replace the brake fluid and bleed it through it pressurised kit.
mbames is offline
Old 30-01-2006, 16:28   #5
Thanks for the replies. I've been using an Eezibleed pressure kit, it's been pretty good in the past on other cars. Just think i'm missing something or not bleeding it in the right order on the old Octavia.
Old 30-01-2006, 17:12   #6
mbames's Avatar
Thats the kit my father uses... I was going to pop home and change my fluid in a few weeks time.
mbames is offline
Old 30-01-2006, 20:20   #7
Smifffy 3 f's's Avatar
I used the eezibleed thing on mine. Started with the wheel furthest from the master cylinder, nsr then osr then nsf then osf. Worked OK on my Octy.
AL.
I'm not bald, I've just got low-maintenance hair.
Smifffy 3 f's is offline
Old 05-03-2006, 18:46   #8
Is there any tricks to bleeding the brakes on the old fashioned way? Just the basic method, or the ignition have to be on or anything. I have bled many cars, but no one with modern ABS.
RallyeSport is offline
Old 06-03-2006, 19:01   #9
No special methods? What spec brake fluid is specified, dot4 or 5.1?
Old 06-03-2006, 19:06   #10
U18 Automotive
Lummox's Avatar
Nothing special required. DOT 4 is fitted as std.
If pumping the traditional way dont push the pedal all the way down, but for the matter of a few quid i'd get an ez bleed kit.
Unit 18 Automotive Services now open Servicing, repairs, modifications you name it we do it. Cupra console bushes at special price, PM for a very competitive quote.
Lummox is offline
Old 12-03-2006, 16:46   #11
Can the piston on the rear calipers be pushed in or must it be screwed in?
Old 12-03-2006, 17:17   #12
U18 Automotive
Lummox's Avatar
It needs to be screwed in with the correct tool.
Lummox is offline
Old 15-03-2006, 18:02   #13
Do you know where I can get this tool?
On the left side, the shape was right, but the distance between them was too short.
