This is a discussion on body trim query within the Octavia I forums, part of the Skoda Model Discussion Area category; Hi all This is probably a simple question, but im looking at colour coding all the black trim on my ...
| Briskodian Join Date: Oct 2007 Location: norwich
Members Car: red octavia vrs Thanks: 5
| body trim query Hi all This is probably a simple question, but im looking at colour coding all the black trim on my red octavia VRS, i was wondering if anybody on this great site knows how to remove them of the car without breaking it, if any body out there can help with anythink like removing the trim, or what fixings they are on or tips that would be fantasic, thanks rev-trev |
| Briskodian Join Date: Feb 2008 Location: redruth cornwall
Members Car: octavia 1.9 tdi ambiente Thanks: 60
| Re: body trim query i have just done my trims on my octy ,and they are pretty easy to remove. for the side trims you will be better off ordering a new set from skoda ,as they tend to kink when you remove them. They only cost 26 plus vat.To remove them ,just carefully prise one end away and pull off .I then used a toffee wheel(look on e-bay) to remove the backing,sprayed the strips and re-applied them.The front and rear trims are held on with clips and can be removed by carefully using a small flat screwdriver to ease one end out ,the you can easily unclip the trim all the way round. When you paint the trims, just sand them with wet and dry, apply a plastic primer ,then apply plenty of coats of high build primer ( sanding between coats) then at least 4 topcoats.I then aapplied 5 coats of clear laquer while the last top coat was still tacky. I dont know whether you need laquer with the red, but i had to use it as mine is silver .IMO the car looks much tidier. hope this helps --dave
__________________ diamond silver octavia,tuning box, pipercross air filter,mak 17 alloys, color coded bumper inserts and rubbing strips,aero wipers |
| Fabia windscreen trim query | Furby164 | Fabia I | 7 | 22-04-2008 17:56 |
| vRS Octy MkII Dashboard trim query. | jonnybravo | Styling and Car Care | 2 | 03-01-2007 13:49 |
| Body coloured trim | lefteye | Styling and Car Care | 1 | 10-07-2006 16:10 |
| +++++ hi every body +++++ | CAPTAIN | INTRODUCE YOURSELF! First time visitors, say hello here. | 8 | 24-12-2004 17:05 |
| Body Colour Exterior Trim | Huck | Styling and Car Care | 11 | 02-07-2003 09:20 |
