This is a discussion on Boost gauge pipe through bulk head... within the Octavia I forums, part of the Skoda Model Discussion Area category; I want to put a boost gauge in the centre console below the stereo. where is a good place to ...
| The Dog of Ange Join Date: Nov 2007 Location: East Yorkshire
Members Car: Skoda Octavia vRS Thanks: 76
| Boost gauge pipe through bulk head... I want to put a boost gauge in the centre console below the stereo. where is a good place to run the vac pipe through on the bulkhead? |
| Briskodian Join Date: Apr 2006 Location: Sheffield
Members Car: Red Octy vRS Thanks: 36
| Re: Boost gauge pipe through bulk head... take off the glove box and behind that there is a black bung stick it though that. Will come out at the side of the pollen filter under the bonnet |
| The Following User Says Thank You to mattbeef For This Useful Post: | Angry Dog (11-12-2007) |
| Re: Boost gauge pipe through bulk head... Thanks Matt - a job for next weekend! |
| Re: Boost gauge pipe through bulk head... no worries mate. all ill say is get the hair dryer on the slam panel to remove it as it makes it so much easier |
| | #5 | |
| Briskodian Join Date: Jul 2006 Location: Cleveland
Members Car: Passat Sport TDi Thanks: 205
| Re: Boost gauge pipe through bulk head... Quote:
| Re: Boost gauge pipe through bulk head... Naa just easier phil ![]() |
| Re: Boost gauge pipe through bulk head... And you t-piece in on the pipe to the top of the fpr? |
| Briskodian Join Date: Nov 2003 Location: Hull,East Yorkshire
Members Car: 02 black magic octavia vrs Thanks: 0
| Re: Boost gauge pipe through bulk head... Yes t piece it off the fpr pipe |
| Re: Boost gauge pipe through bulk head... yea ill try and dig up Robs post with the T Piece. feck i cant find it but im sure that someone will come along with the magic picture lol |
| | #10 | |
| SMOGUS MAXIMUS Join Date: Jan 2005 Location: Essex
Members Car: Toyota Auris SR180 Images: 3 Thanks: 50
There you go..................LOL ![]() | |
| The Following User Says Thank You to Beretta For This Useful Post: | Angry Dog (09-01-2008) |
| | #11 |
| Re: Boost gauge pipe through bulk head... Cheers mate i knew someone would have a close up ![]() |
| | #12 | |
| Why So Serious Join Date: Jan 2006 Location: "What" ...What ain't no god damn country
Members Car: a car Thanks: 271
| | #13 |
| Re: Boost gauge pipe through bulk head... hahaha i just read that back now. Whoops |
| | #14 |
| Briskodian Join Date: Dec 2007 Location: Chippenham
Members Car: 53 Fabia vRS Thanks: 22
| Re: Boost gauge pipe through bulk head... Are 'Zip Ties' strong enough to hold the vacuum pipe on at boost? Dave |
| | #15 |
| Hardcore Join Date: Feb 2006 Location: Bahrain
Members Car: Fabia vRS Thanks: 200
| Re: Boost gauge pipe through bulk head... Another place is the grommet above the clutch pedal - needs the lower fascia removed. Gonna crack on with this over the next 2 days...
__________________ Fab vRS - Black Magic - PD160 intake - Forge FMIC - colour coded front grille -SLC Splitter - K&N Airfilter -SEAT Strutbrace - Jabba ARB - IC Waterspray (need to wire it in!) - 312mm TT brakes - Eibach Springs - Skoda Reversing sensors - Devonutopia Tuning (tm) Custom Exhaust (2 1/4" straight pipe) - Short shifter mod- 5 brake light mod - Helix Steel SMF + Organic Clutch + pressure plate - Peloquin LSD - TD stage 2 Hybrid - Washbrook remapped ECU - Uprated injectors - Cupra bushes -Poly-filled dogbone - Allard racepipe - Pirelli Dragons - Forge Rear Strutbrace - DIY SS upper boostpipe delete -Koni FSD's - elephant pipe CCV mod |
| | #16 |
| Briskoda Staff Join Date: Oct 2005 Location: North Yorkshire
Members Car: AUDI A4 B7 2.0 TDI SE Saloon Thanks: 206
| Re: Boost gauge pipe through bulk head... I uses the the gromit above the pedal box. I ran my gauge in the drivers air-vent. So the pipework was better coming through the right side of the car rather than left.
__________________ ![]() ![]() '05 Audi A4 2.0 Tdi SE - no mods until the warrenty expires ... yeah right... interior light pack, 3 spoke mfsw.'00 Audi A4 2.8 Quattro - Gone.... (bleeding money pit )Audi A4 2.6 Avant (Breaking - Check out http://shop.ebay.co.uk/merchant/auroan) |
| | #17 |
| Re: Boost gauge pipe through bulk head... i dont want to lose any vents.. i like them to clear windows, heat and cool the cabin etc lol |
| | #18 |
| Re: Boost gauge pipe through bulk head... yeah, I know what you mean. But I found the driver's side one (in between steering wheel and door handle) never really did anything apart from annoy me (so it got closed anyway)
| | #19 | |
They sure are. ![]() HTH | |
| | #20 | |
| | #21 |
| Briskodian Join Date: Jun 2006 Location: Melksham
Members Car: vRS Thanks: 3
| Re: Boost gauge pipe through bulk head... Mike, I took mine through the electrical connector box under the windscreen on the drivers side, drilled a hole in the top cover and fitted a tight grommet to feed the pipe through. I did it at the same time as i fed the cable through for cruise control ![]() |
| | #22 |
| Briskodian | Re: Boost gauge pipe through bulk head... where did you get the t piece from. im looking at getting a boost gauage. do you get all the connectiosn with the guages or do you have to buy them separately
__________________ Skoda Owners are not image concious. 02 Octy VRS SOLD 94 Supra TT GZ now on the drive. |
| | #23 |
| Re: Boost gauge pipe through bulk head... you normally get them seperarely. I sell sell gauges with everything required (except some where to mount it, but watch this space ) |
| | #24 |
| Briskodian | Re: Boost gauge pipe through bulk head... have u got a pic of the gauges u sell and a price mate?
| | #25 |
| Briskodian | Re: Boost gauge pipe through bulk head... right i got sum tubing witht the gauge. its a clear plastic one. im wonderi9ng it its going to be strong enough. does this piece of pipe need clamping too? and would a zip tie be strong enouhg in this case?
