This is a discussion on Boost leak, help with part number please. within the Octavia I forums, part of the Skoda Model Discussion Area category; Have got a boost leak which i heard and later found today. I need help with a pipe part number ...
| Need more power Join Date: Feb 2007 Location: Driffield, Good old yorkshire
Members Car: octavia VRS Thanks: 54
| Boost leak, help with part number please. Have got a boost leak which i heard and later found today. I need help with a pipe part number please. The pipe is joined to another by a wrap around sleeve and is one of 2 pipes which comes from the middle of the inlet manifold. I have included a bad pic of the offending pipe ( there is another pipe to the left which is not pictured which i don't want). I have checked ETKA but it is only showing 1 pipe leaving the middle of the manifold but mine has 2 from the middle. Thanks ![]()
__________________ Regards Martin Turbo back blueflame exhaust |
| Briskodian Join Date: Apr 2006 Location: Sheffield
Members Car: Red Octy vRS Thanks: 36
| Re: Boost leak, help with part number please. Err pass mate as mine only has one pipe from the mani |
| Re: Boost leak, help with part number please. New pic its the right pipe ![]()
| Om nom nom nom Join Date: Feb 2003 Location: Manchester
Members Car: A White Car Thanks: 79
| Re: Boost leak, help with part number please. Part number i got was 06a103221bk - i replaced this last week. |
| The Following User Says Thank You to Neo_VR For This Useful Post: | martziniuk (08-05-2008) |
| NOW @ PEUGEOT Join Date: Nov 2003 Location: Bicester,Oxfordshire
Members Car: 2 x octavia vrs 03&01 Thanks: 32
| Re: Boost leak, help with part number please. If its the one on the right hand side of the inlet then i have just replaced mine... 06A103221BK mine cost £9.73 +vat. If that has gone i would also change the Y shaped one off the rocker box S06A103221BH £22.84 +vat HTH Phil
__________________ 1)RED ONE, FEW MODS; AND A HEALTHY 237bhp 2)GONE BUT NOT FORGOTTEN, 2ND OWNER OF THE BLACK BEAST, GOD WHAT A HOOT ![]() LACK OF PLANNING ON YOUR BEHALF DOES NOT CONSTITUTE AN EMERGENCY ON MINE |
| The Following 2 Users Say Thank You to piv34uk For This Useful Post: | lescargot (17-05-2008), martziniuk (08-05-2008) |
| Re: Boost leak, help with part number please. Thanks, can you tell me if it came with the other pipe, there is a sleeve which wraps them both together. So is the pipe a crankcase breather or something to do with the inlet manifold?
__________________ Regards Martin Turbo back blueflame exhaust Last edited by martziniuk; 08-05-2008 at 21:56. |
| Re: Boost leak, help with part number please. No... Just one on its own, mine had an inch long cut in it... Wasnt the end of my problems though as the Maf decided to go pop Phil
| Re: Boost leak, help with part number please. snap, an inch is spot on.
| | #9 | |
| Re: Boost leak, help with part number please. Quote:
Dont forget you will need new jublee clips for it too.. either order from dealers at same time or get some from halfords.. I managed to DIY it after unbolting that black metal plate thing and pushing it out the way. | |
| | #10 | |
![]() I had the black plate to the side tonight thats how i found it. Come to think of it i have been getting a smell of oil in the cabin on idle. Think i found the cause.
__________________ Regards Martin Turbo back blueflame exhaust | |
| | #11 |
| Briskodian Join Date: May 2004
Members Car: Golf G60 but VRS and Elegance TDi in the household Thanks: 0
| Re: Boost leak, help with part number please. Sorry to hi-jack the thread but could this be the problem with my brother VRS also? Sometimes its fine with full performance and sometimes its flat, with no boost. Following advice on another thread I've replaced the turbo outlet pipe for the modified one, cleaned the throttle body, replaced the DV for a 710n. But the problem is still there? |
| | #12 |
| Re: Boost leak, help with part number please. Vag-com will give you the answer, but a possible thing could be the N75 valve if your not getting boost Phil
| | #13 | |
telltale signs are oily residue and crap round the dipstick area (ooo err missus) and if you can get your hand down there when the engines running and wiggle the pipes you may be able to hear a difference in noise. i noticed mine from a definate hissing that could be heard at idle, wiggling the pipes made the noise change a bit See this thread for more info | |
| | #14 |
| Re: Boost leak, help with part number please. Got mine ordered today, should be in tomorrow. Audi price £10.81 +vat .... jizzing sods. For reference I never got any fault codes.
__________________ Regards Martin Turbo back blueflame exhaust Last edited by martziniuk; 09-05-2008 at 20:20. |
| | #15 | |
| Briskodian | Re: Boost leak, help with part number please. Quote:
Has the car been remapped at all and has the car got any fault codes showing? I'm assuming you have VAG com. Darren
__________________ Octavia 2004 in Red. Now for sale http://www.pistonheads.com/classifieds/543161.htm | |
| | #16 |
| Re: Boost leak, help with part number please. No its a stock car, it has the infamous (so it seems) 17705 pressure drop fault code. I had access to VAG-COM. However my own full version should be here tomorrow ![]() |
| Boost / Vac Leak Tester | sabredylan | Maintenance & Performance | 4 | 03-06-2008 12:49 |
| Newbie with a boost/oil leak ? | labviewer | Fabia I | 4 | 20-12-2007 13:48 |
| part number help please? | TeflonTom | General Car Chat | 5 | 08-11-2007 12:18 |
