This is a discussion on Brake calliper question - Rear disc within the Octavia I forums, part of the Skoda Model Discussion Area category; Great set of forums (I'm new to the site). I wonder if anyone can help with a query I have. ...
| Briskodian | Brake calliper question - Rear disc Great set of forums (I'm new to the site). I wonder if anyone can help with a query I have. I am about to change the rear discs and brake pads on my Octavia vRS (2002). I haven't started the job yet (and no workshop manual to date) but I assume the pistions in the callipers have threaded inserts to accomodate for brake pad wear to keep the handbrake automatically adjusted? What type/direction of thread is used? Is it the same thread on the left and right hand sides or does one side use a conventional right hand thread (clockwise to tighten) and one a left handed thread? Any useful tips for making the job as easy/painless as possible? Many Thanks |
Members Car: Octavia 1.8T 4X4 Estate & Fabia vRS Thanks: 51
| Re: Brake calliper question - Rear disc You will need a suitable brake wind back tool. Sealey do the set below which caters for most if not all European cars, but you can buy a tool for the VAG range of cars for a fraction of the price of that set. Some Halfords may stock the tool you need. The calipers retract by rotating them in a clockwise direction.
__________________ Denis 2002 Octavia 1.8T 4X4 turbo Estate - rebreathed on by Jabba ... 31.93mpg2007 Fabia vRS - CC, ESP and full leather trim by Seat Surgeons ...48.57 mpg... Last edited by DGW; 10-07-2006 at 13:21. |
| Briskodian Join Date: Feb 2005 Location: Bedfordshire
Members Car: Octavia Elegance Estate TDi 130bhp. Thanks: 1
| Re: Brake calliper question - Rear disc I'm just about to start the same job on a 2003 Elegance (130bhp), so many thanks from me also!! |
| Re: Brake calliper question - Rear disc A tip sometimes usefull, you dont need to unbolt the carriers even if your changing the disc. One the caliper is off the disc will slide out. So you need a 13mm and 15mm spanner and the wind back tool as your base tools. |
| Briskodian Join Date: Oct 2003 Location: shropshire
Members Car: skoda octavia VRS Thanks: 10
| Re: Brake calliper question - Rear disc take off the reservoir cap while winding them back.
__________________ louder than war |
