39,396 Members 1,487,241 Posts
Brake Disk Corrosion
This is a discussion on Brake Disk Corrosion within the Octavia I forums, part of the Skoda Model Discussion Area category; All I have notices specs of what looks like rust specs on all four brake discs. This is a 55 ...
Old 11-08-2008, 23:23   #1
Members Car:
All
This is a 55 plate, with 29k on the clock and was mentioned at the last service two months ago, but not as in needing any work done yet.
After driving for a few miles and braking etc this disappears.
I am due for its first MOT end of this month, and am wondering if this could be a failure?
personally, this seems quite unusual for a 3 yr old car with average mileage.
was too dark to add photos, but will add if this helps.
dont suppose there anything i can do under warranty? i got three weeks left in that!
Thanks
Gordon
gordonium is offline
Old 11-08-2008, 23:33   #2
Ho Ho Ho
Conshine's Avatar
Members Car: Silver Fabia vRS
Re: bRAKE DISC CORROSION
The discs will show specs of rust on them if you leave them for a while or after rain as the metal disc is ecposed to the elements and it just starts to rust.
Nothing to worry about, my fabia does it on a 4 discs if you leave it and it's gone when you drive after a few presses of the pedal.
I have just had all 4 discs replaced too so I wouldn't worry, don't think it's a failure.
So long at they are not pitted you should be fine.
Ben
Conshine is offline
The Following User Says Thank You to Conshine For This Useful Post:
gordonium (11-08-2008)
Old 12-08-2008, 08:30   #3
cjb
Discs always rust- like Conshine says, they are steel, so there's no way they won't.
As long as they aren't worn, scored, pitted, or the pads aren't contacting the full width because of a stuck caliper, they are fine.
-- Chris
The Devil may care, but I don't mind.
cjb is offline
The Following User Says Thank You to cjb For This Useful Post:
gordonium (12-08-2008)
Old 12-08-2008, 08:43   #4
Bodge's Avatar
Members Car: '02 Octavia RS
you should have seen mine the other day after i used 'wonder wheels' on the rims! Rusterama!
It's perfectly normal, and will always happen. Zero concern.
Diamond Silver '02 Octavia vRS hatch
Bodge is offline
The Following User Says Thank You to Bodge For This Useful Post:
Old 12-08-2008, 08:45   #5
ASZ Eternal
ap0gee's Avatar
Members Car: Black Magic Fabia vRS
They're actually cast iron, but other than that, a big on all the above
ap0gee is offline
The Following User Says Thank You to ap0gee For This Useful Post:
Old 12-08-2008, 20:31   #6
Members Car:
Re: Brake Disk Corrosion
will find out tomrow!! thanks guys, if they say something, i will set you all on them!!
Old 12-08-2008, 20:47   #7
Cupra Bush King
Lummox's Avatar
Images: 2
Unless they are ceramic (as your being picky)
www.unit18.co.uk
Lummox is offline
Old 12-08-2008, 20:49   #8
mark_sargeant19's Avatar
mine go a lovely tango orange colour about 30mins after washing, not fussed tho
2001 Black Magic Octy Vrs ** Ebay CAI ** Forge SPLRT DV ** Jetex 200CEL Sports cat ** Hayward and Scott turbo back exhaust ** ** Sprayed grill ** LCR Splitter ** DIY Darkened Headlights ** Full sound system
mark_sargeant19 is offline
Old 13-08-2008, 12:21   #9
KenONeill's Avatar
Members Car: Octavia TDi110
If we're going to get picky
There's also carbon matrix discs, and the difference between "cast iron" and "steel" is normally the percentage of carbon in the alloy.
KenONeill is offline
Old 13-08-2008, 12:31   #10
anewman's Avatar
Images: 1
My car hasn't been used for a few months - you ought to see my brake discs
94 Favorit GLXIe Estate
Briskoda "Banger" social group
anewman is offline
Old 13-08-2008, 19:23   #11
Banana-Man's Avatar
Members Car: Octavia RS
Feel with your fingers if they are pitted - that's the type of corrosion they will fail MOT. Left standing the brakes always rust, this is normal and will go nice and shiney when you use the car.
Don't Worry!!!
WOW GUYS!!!! look at all my 5 fantastic mods: Green valve caps on each wheel
Banana-Man is offline
Old 13-08-2008, 20:17   #12
vRSLen's Avatar
Members Car: MK11 Octavia vRS
Just drive the bl00dy thing
Current car: Black MKII Octavia vRS Combi
Previous: Black MKI Octavia vRS Combi
Black Fabia Elegance 100 BHP
vRSLen is offline
Old 13-08-2008, 20:21   #13
jamesmckelvie's Avatar
Members Car:
why do they fail the mot if they are pitted slightly?
1.9 TDI Elegance - Cappuccino Beige
Plenty enough power and torque for the economy offered
jamesmckelvie is offline
Old 13-08-2008, 20:59   #14
Banana-Man's Avatar
If they are pitted there firstly is a much less surface area for the pads to stop them. The surfaces are uneven and the brakes could fade rapidly. Worst of all if the disc are pitted this could lead to the rust fracturing the disc and then you could end up in a wooden overcoat.
It's normally rears get pitted.
The Following User Says Thank You to Banana-Man For This Useful Post:
jamesmckelvie (13-08-2008)
Old 11-09-2008, 17:42   #15
cookie-859's Avatar
Members Car:
My 53 Octavia failed its first MOT because of pitted discs!! Haven't had that sort of trouble with any of my previous cars [Not Skodas!]
cookie-859 is offline
Similar Threads
Erm, is corrosion like this normal on rear brake discs ultra_joel88 Fabia I 17 14-04-2008 08:45
rear disk brake conversion PDPower Fabia I 0 03-01-2006 19:18
Brake disk advice.... ecklad Octavia I 7 26-09-2005 21:48
Brake Disc Corrosion bertJ Fabia I 8 05-01-2005 18:19
how does the brake disk winding tool work? anotherbadname Maintenance & Performance 2 07-08-2004 16:13
