This is a discussion on Brake fluid - 5.1? within the Octavia I forums, part of the Skoda Model Discussion Area category; Hello Guys In the next revision I will change the oil brakes. Someone recommend the Ferodo 5.1? And about quantity, ...
| Briskodian | Brake fluid - 5.1? Hello Guys In the next revision I will change the oil brakes. Someone recommend the Ferodo 5.1? And about quantity, one liter will be enough? The car is Oct. VRs – AUQ 2003. Cordially, A. Luís ![]() |
| Crossdresser Join Date: Apr 2003 Location: fast lane
Members Car: Citroen C-Crosser 2.2HDI Thanks: 25
| Re: Oil Brekes - 5.1? I think you mix up two things here. Brake pads (Ferodo DS2500) and Brake fluid (Castrol Super RS 4.1). Judging by your last statement you want the brake fluid. And IIRC, they come in 500ml bottles, so you'd need two (it is slightly less than 1L). edit: changed from 5.1 to 4.1 as i had my facts wrong) Last edited by Quinten; 17-07-2006 at 12:57. |
| Site Sponsor | Re: Oil Brekes - 5.1? I was told that if you go from dot4 brake fluid on to dot5.1 you have to flush the system. As this is 2 totally differnt types of fluid? I think that a good quality dot4 brake fluid is usually ok and just replace it every 2 years as stated in the service manual Sarah |
| Briskodian | Re: Oil Brekes - 5.1? Go to super dot 4.1 seems the recomendation as dot 4.1 isn't far behind 5.1 when dry and is much better when wet, so you won't need to change it every 5 minutes.
Members Car: Octavia TDi110 Thanks: 63
| Re: Oil Brekes - 5.1? Yeah Sarah, you've got that right. Dot 4.1 is a conventional mineral fluid (but higher boiling point than numerically lower specs like dot 3 or dot 4). Dot 5 and 5.1 are silicone based, so you need to flush the system to get the mineral fluid out, and then hope you don't get a water lock (like an air lock but harder to bleed out) in the system. Dot 5's not worth considering except on dedicated race or rally cars. |
Members Car: Octavia 1.8T 4X4 Estate & Fabia vRS Thanks: 51
| Re: Oil Brekes - 5.1? The fluid capacity of the brake system is 0.6L.
| Briskodian | Re: Oil Brekes - 5.1? I use Dot 5.1. And sorry to disagree but 5.1 is NON silicone based. DOT 5.1 is Glycol based, the same that Dot 3 and 4. So you can switch between 3, 4 and 5.1 with no problem. You can even mix them up. |
| | #8 | |
| Briskodian Join Date: Jun 2006 Location: Ely, Cambridge.
Members Car: Magic black Octavia vrs on '52 plate. Thanks: 1
| Re: Oil Brekes - 5.1? Quote:
As far as i'm aware, the above is correct with dot 5 being the silicone fluid and dot 5.1 being interchangeable with 3 and 4.
__________________ My other Skoda's a Nissan.... | |
| Site Sponsor | Re: Brake fluid - 5.1? I was told different. So look in to it before you do it , that would be my advice Sarah |
| | #10 |
| Dinosaur Join Date: Oct 2002 Location: North of the Watford Gap
Members Car: Merc E class & SLK Thanks: 19
| Re: Brake fluid - 5.1? I thought fluid capacity was 1.5 litres including the ABS chambers
__________________ A jolly sensible Mercedes E class saloon in a rather fetching bluey grey colour. No it isn't fast, no it isn't modded, and yes, it will still eat your Fabia for breakfast. Official mobile chicane for Briskoda trackdays ![]() |
| | #11 |
| Briskodian | Re: Brake fluid - 5.1? Hello Again. The Ferodo Dot 5.1 Brake Fluid is compatible with dot 4.0. I want to know if someone has tried? And the full capacity off the system brake (0,6 or 1.5 l)? http://marketplace.s2ki.com/s2ki/pro...&cat=24&page=1 Cordially, A. Luís |
| | #12 |
| Re: Brake fluid - 5.1? Ok guys; I was told by a usually reputable source that dot 5.x was a standard for silicone fliuds. |
| | #13 |
| Briskodian Join Date: Dec 2005 Location: North West England
Members Car: Octavia vRS Thanks: 0
| Re: Brake fluid - 5.1? DOT 4 and DOT 5.1 are compatible AFAIK. I use DOT 5.1 in my mountain bikes. It resists heat, but it needs frequent (well, yearly!) flushing through as it seems to absorb moisture quite quickly.
__________________ Mk1 Octavia vRS. The thinking man's Hot Hatch. PS. Give Cyclists Room! We're quite vulnerable. If I can slap your window, you're too close Last edited by MC Bodge; 18-07-2006 at 13:11. |
| | #14 |
| Briskodian | Re: Brake fluid - 5.1? Personally I would still go with super dot 4.1 as it performs much better when damp and only marginally worse when wet ![]()
| | #15 |
| Re: Brake fluid - 5.1? As mentioned DOT 3,4 and 5.1 are all the same typre of fluid and can be mixed, however you will alter the spec of the fluid by doing so. DOT 5 is silicone based and quite different, usually kinda pink in colour aswell. Super DOT 4 seems to be a good compromise, IIRC DOT 5.1 attracts moisture quicker. Either way just a damn good fluid change with factory DOT 4 fluid will make a vast difference if the fluid is getting old. Since DOT 4 fluids were developed, it was recognized that borate ester based fluids offered the potential for boiling points beyond the 446F requirement, thus came the Super DOT 4 fluids - some covered by the DOT 5.1 designation - which exhibit a minimum dry boiling point of 500F (same as silicone, but different chemistry). Last edited by Lummox; 18-07-2006 at 20:09. |
| | #16 |
| Briskodian | Re: Brake fluid - 5.1? From the Department of Transportation (DOT): Standard No. 116: Motor Vehicle Brake Fluids S5.1.14 Fluid color. Brake fluid and hydraulic system mineral oil shall be of the color indicated: DO3, DO4, and DO5.1 non SBBF colorless to amber. DO5 SBBF purple. S5.2.2 Certification, marking, and labeling. S5.2.2.1 Each manufacturer of a DOT grade brake fluid shall furnish to each packager, distributor, or dealer to whom he/she delivers brake fluid, the following information: (b) The grade (DO3, DO4, DO5) of the brake fluid. If DO5 grade brake fluid, it shall be further distinguished as "DO5 SILICONE BASE" or "DO5.1 NON SILICONE BASE." (e) Certification that the brake fluid conforms to DO5 SILICONE BASE, or DO5.1 NON SILICONE BASE as applicable. |
