This is a discussion on Brake Fluid within the Octavia I forums, part of the Skoda Model Discussion Area category; Having checked and double checked the Service Book and paperwork i got with the car i'm now certain the brake ...
| Briskodian Join Date: Jan 2007 Location: North East
Members Car: Skoda Octavia vRS Thanks: 4
| Brake Fluid Having checked and double checked the Service Book and paperwork i got with the car i'm now certain the brake fluid has not been changed in the last 3 years. 1. Should i get Skoda to do this or can i get the garage down the road to do it for me? 2. Is their any special brake fluid i should ask them to put in for me for a vRS (no mods)? Thanks....
__________________ Al.... Skoda Octavia vRS 04 in silver |
| Briskodian Join Date: Feb 2007 Location: East Sussex and Sometimes North Yorks. and sometimes in between!
Members Car: Skoda Octavia VRS Thanks: 32
| Re: Brake Fluid I've just had my 2 year 20k service and the dealer suggested it was about time it were done...
__________________ Octavia Mk 1 VRS, Black Magic |
| Dinosaur Join Date: Oct 2002 Location: North of the Watford Gap
Members Car: Merc E class & SLK Thanks: 19
| Re: Brake Fluid Should be evry 2 years 40k miles IIRC As you are out of warranty, get it done wherever is cheapest ![]() As for type of fluid, unless you are unhappy with standard stuff, just use that. Handbook will tell you what sort.
__________________ A jolly sensible Mercedes E class saloon in a rather fetching bluey grey colour. No it isn't fast, no it isn't modded, and yes, it will still eat your Fabia for breakfast. Official mobile chicane for Briskoda trackdays ![]() |
| Briskodian Join Date: Jun 2005 Location: NW Kent
Members Car: Metalic Black 1.8T 4x4 Estate Thanks: 9
| Re: Brake Fluid If your "gunna" change it, go for the latest DOT4 spec. It don't absorb water, don't burn your paintwork & has a higher boiling point.
__________________ Deli G ,,,, leader of the Peckham Massif! KW Coilovers fitted, Forge TIP fitted, KK fitted, Blueflame full system fitted, CAI fitted, Forge 007 D/V fitted, PBVH4 fitted, Forge adjustable rear tie bars fitted, FMIC fitted, 312's fitted, Tints fitted. Was that a 4x4 Skoda??? It's IMPOSSIBLE! 197.2 BHP & 263.1Nm Last edited by Wayne Kerr; 23-02-2007 at 19:44. |
| Briskodian | Re: Brake Fluid http://www.briskoda.net/forums/maint...-thread/65339/ That explains brake fluids. For a VRS DOT 4, or DOT 5.1 (sometimes called super DOT 4) will be fine, with the 5.1 being better.
| Re: Brake Fluid 2 years, no mileage interval on brake fluid. |
| Re: Brake Fluid
__________________ Deli G ,,,, leader of the Peckham Massif! KW Coilovers fitted, Forge TIP fitted, KK fitted, Blueflame full system fitted, CAI fitted, Forge 007 D/V fitted, PBVH4 fitted, Forge adjustable rear tie bars fitted, FMIC fitted, 312's fitted, Tints fitted. Was that a 4x4 Skoda??? It's IMPOSSIBLE! 197.2 BHP & 263.1Nm |
| Briskodian | Re: Brake Fluid It means you change it at two years whether you have done 1 mile or 1 million miles. It the fact that brake fluid absorbs water that degrades it far more than mileage, so in 2 years it has absorbed enough water to be less effective so should be replaced.
| Re: Brake Fluid Is it easy to change your own brake fluid? Just waiting for my Haynes manual to arrive!
| | #10 |
| Briskodian Join Date: Feb 2007 Location: Shropshire
Members Car: Octavia TDI 110 Estate Thanks: 0
| Re: Brake Fluid Hi, Just bought an Octavia TDI estate. I'm halfway through changing the fluid and it's full of little crystals, the last time I can see that the fluid was replaced was 3 years ago. One of the caliper guide pins was just pushed in the whole in the wheel hub (no thread at all)! Quality servicing eh? I should have read the threads on here ref. rear pad changing. Haynes needs to have ago at using circlip pliers on the rear pistons. I made my own tool once I knew what a proper one looked like. |
| | #11 | |
| Re: Brake Fluid Quote:
__________________ Deli G ,,,, leader of the Peckham Massif! KW Coilovers fitted, Forge TIP fitted, KK fitted, Blueflame full system fitted, CAI fitted, Forge 007 D/V fitted, PBVH4 fitted, Forge adjustable rear tie bars fitted, FMIC fitted, 312's fitted, Tints fitted. Was that a 4x4 Skoda??? It's IMPOSSIBLE! 197.2 BHP & 263.1Nm | |
| | #12 | |
| Briskodian | Re: Brake Fluid Quote:
__________________ Cars make CO2 and trees absorb CO2. By driving your car you're feeding a tree and helping the environment. | |
| | #13 |
| RICHARD Join Date: Apr 2005 Location: Twickenham - Middlesex
Members Car: Skoda Fabia >> VW Golf >> Seat Ibiza >> VW Polo Thanks: 11
| Re: Brake Fluid Yup as per lummux we reccomend every two years.
__________________ First Car: Skoda Fabia MK1 1.2 12v Comfort Replaced with: Volkswagen Golf MK4 GT 1.9TDI Replaced with: Seat Ibiza MK4 Sport 1.9TDI Replaced with: Volkswagen Polo MK6 Ltd. Edition Sport 1.4 16v |
