This is a discussion on Brake pad replacement within the Octavia I forums, part of the Skoda Model Discussion Area category; i need to replace the pads on my 1.9tdi, any ideas as to a decent set but not mega bucks. ...
| Briskodian | Brake pad replacement i need to replace the pads on my 1.9tdi, any ideas as to a decent set but not mega bucks. i dont mind paying around £50, and i dont have a clue if you can even get decent pads for that. Bit to un-educated when it comes to the greasy bits. any ideas much appreciated. cheers guys. |
Members Car: 4x4 turbo estate Thanks: 17
| just get some big name decent pads from your local specialist, they will be able to point you in the right direction. probably a lot cheaper than the dealer too
| Dinosaur Join Date: Oct 2002 Location: North of the Watford Gap
Members Car: Merc E class & SLK Thanks: 19
| Greenstuff or redstuff.
__________________ A jolly sensible Mercedes E class saloon in a rather fetching bluey grey colour. No it isn't fast, no it isn't modded, and yes, it will still eat your Fabia for breakfast. Official mobile chicane for Briskoda trackdays ![]() |
| Briskodian | thanks guys |
| Briskodian Join Date: Jan 2005 Location: Manchester UK
Members Car: Octavia TDi (me),Fabia TDi (wife),Fabia VRS SE (son) Thanks: 2
| If you are doing the rear brakes you will have to use a caliper windback tool or you will break the handbreak mechanism |
| Briskodian | cheers mate, but im buying the pads and giving em to the local garage. id proberbly make a whole lot of mess. cheers anyway. |
| Discordian Join Date: Jan 2003 Location: Newport, Newport - so good the Post Office named it twice
Members Car: Octavia vRS hatch, 1.8T Thanks: 0
| I'll echo TaviaRS's suggestion - EBC Redstuff or Greenstuff. Greenstuff aren't much more expensive than OEM pads, and should be OK for road use (rumour has it that they melt or catch fire on trackdays ) Greenstuff rears are around £30 a set.Redstuff C should be OK for trackdays, but EBC don't seem to do them for the rear of a standard Octy. I've compromised, and have Redstuff C front, & Greenstuff rear. No problems yet, but then I do drive like a Granny ![]() Redstuff C fronts will cost around £60 a set.
__________________ Mike |
| Brakes: Brake Fade Causes And Cures | TaviaRS | Technical Guides | 4 | 21-04-2006 00:37 |
| Brake Judder - replacement discs? | Stubax | Maintenance & Performance | 5 | 06-07-2004 17:14 |
| Preparing a road car for track day use | Real Skoda | Maintenance & Performance | 8 | 10-04-2004 19:20 |
| Preparing a road car for track day use | Real Skoda | Maintenance & Performance | 0 | 10-04-2004 05:48 |
| Can You Explain Dot Ratings On Brake Fluids? | ColinD | Maintenance & Performance | 0 | 09-07-2003 13:17 |
