This is a discussion on Brake upgrade within the Octavia I forums, part of the Skoda Model Discussion Area category; I need to upgrade my brakes after my mk1 octavia being remapped. I have read that 312mm disc would fit ...
| Briskodian | Brake upgrade I need to upgrade my brakes after my mk1 octavia being remapped. I have read that 312mm disc would fit without much modification. Is this size disc standard on other models in the VW family or are these after market jobs? Also is it necessay to upgrade the rear brakes as well? Thanks |
| Briskodian Join Date: Aug 2005 Location: North London
Members Car: Octy 4x4 1.8T Elegance Hatch Thanks: 27
| Re: Brake upgrade Try having a search as it brought up loads of info before I did this mod. The setup is used on the vrs and some Audi models I believe (think my new set were for an Audi TT quattro). Rear brakes dont do a heck of a lot compared to front and the braking balance isnt thrown out at all by the bigger front increase imo. Lee
__________________ ![]() Thanks to JKM: REVO STAGE 2+ remap, Evoms CAI, Piper Turbo back Exhaust, Autotech Fuel Pump, Torque Arm Insert, Forge Recirc, Neuspeed Turbo & Intercooler pipes, APR FMIC, Iridium plugs, Koni FSD's, Eibach springs, Eibach F + R anti roll bars. VF short shifter. 345mm Brakes. 280BHP & 330LB/FT - enough room for a proper trip to B&Q and 36mpg on a run!!! |
| Briskodian | Re: Brake upgrade Thanks for the info. |
| Briskodian | Re: Brake upgrade Will I need to get 17" and do I have to get the calipers as well or will my calipers fit? |
| | #5 | |
| Briskodian Join Date: Sep 2004 Location: Sheffield UK
Members Car: Octavia 1.8 20V Turbo Laurin & Klement Thanks: 5
| Re: Brake upgrade Quote:
but to answer your question i was told that you would only need the carrier and not the caliper as these are the same. But i just had the lot fitted i also seem to recall that the guys at JBS said it isnt a good idea replacing the discs without new pads too - if that helpsLee
__________________ What is: Octavia vRS... Black Magic yet again... with plenty planned ![]() What was (May she RIP): Blk Magic Octy (Not quite a VRS) L&K,Climate,Heated leather,Cruise,Xenons, MODS(so far): Custom Code Phase II JBS-Forge-007P DV, Forge/Samco TIP, 18" Ace 205's, ABD/JBS CAI (*Wooosh), Audi TT 312mm Brakes | |
| | #6 | |
| BRISKODA Staff | Re: Brake upgrade Quote:
What car do you have? Regardless uprating the pads, Ferredo DS2500, and fluid, Castrol Response 4.1+...will make a big improvement in terms of fade and feel. I'd say do the discs if you intend to take in a few track days.
__________________ Adrian. | |
| Briskodian | Re: Brake upgrade I have a 1.8T Elegance that has just been Jabba'd. Thanks for the info on the pads, etc. That seems a lot more cost effective as I dont intend to do any track days in the foreseeable future |
