This is a discussion on Brake wear indicator within the Octavia I forums, part of the Skoda Model Discussion Area category; My brake wear indicator light has been coming on most of the time for a while now so I decided ...
| Briskodian | Brake wear indicator My brake wear indicator light has been coming on most of the time for a while now so I decided to take the front wheels off and have a look what's going on. All pads are fine, although this isn't significant because the brake wear indicator cable was cut...... So, I tried insulating the two wires to see if this turned the warning off, it didn't, then I tried joining the two wires to see if that turned the warning off, it didn't..... Each time I turned the ignition off and took the key out, is it neccasary to disconnect the battery to get warning lights to reset or anything like that? With brake pads with a wear sensor in the would it be open circuit when they're worn or closed? Thanks |
| Briskodian Join Date: Jul 2006 Location: South Birmingham
Members Car: Red Octavia vRS 1.8T (20v) Thanks: 46
| Re: Brake wear indicator i joined the 2 wires to cancell mine off the dash.
__________________ Support Briskoda----------------------> ![]() Red Skoda Octavia V//RS Mods to date: Carbonio CAI Forge 007 DV Aero Wipers Briskoda Stickers KVW100 GB Wheel Inserts RS Tuning Remap Delocked Piper Cat Back Kenwood KDC-W6541U Fli Twin 12" Active Sub Parrot CK3100 ------------------------------------------------ ![]() |
| Briskodian Join Date: Jul 2007 Location: Oxfordshire
Members Car: Octavia Vrs Thanks: 37
| Re: Brake wear indicator could be a brake elsewhere on the wire?
__________________ Must Go Faster |
| Briskodian | Re: Brake wear indicator that's my worry! Does anybody know how I could test that?! Or how could I fool the system into turning the warning light off by some other means? |
| Re: Brake wear indicator try a volt meter on the cable to see if any voltage is reaching the sensor would be my 1st test.
| | #6 | |
| Re: Brake wear indicator Quote:
__________________ Support Briskoda----------------------> ![]() Red Skoda Octavia V//RS Mods to date: Carbonio CAI Forge 007 DV Aero Wipers Briskoda Stickers KVW100 GB Wheel Inserts RS Tuning Remap Delocked Piper Cat Back Kenwood KDC-W6541U Fli Twin 12" Active Sub Parrot CK3100 ------------------------------------------------ ![]() | |
| Re: Brake wear indicator If you join the two wires properly then it should go out. Providing your fluid level is ok. |
| Pad wear indicator/Vag com | puddener | Superb | 15 | 18-04-2008 13:47 |
| Brake wear indicator - any other reason!?! | duncan502 | Octavia I | 6 | 02-10-2005 19:13 |
| Brake pad wear indicator | SimonT | Maintenance & Performance | 6 | 20-02-2004 18:16 |
