This is a discussion on broken parking sensors??????? within the Octavia I forums, part of the Skoda Model Discussion Area category; Has anybody had any problems with there parking sensors?? Why i select reverse a beep tells me that i am ...
| Briskodian Join Date: Apr 2006 Location: leamington spa
| Has anybody had any problems with there parking sensors?? Why i select reverse a beep tells me that i am in reverse, But today select reverse and a long high pitched tone comes on, then when reversing nothing!!!!!!! any ideas please. |
| Hairy Yeti Join Date: Sep 2003 Location: Newport Pagnell
| Sounds like a sensor has gone defective, a VAG COM check can identify which one.
__________________ Unit 18 now open Servicing, repairs, modifications you name it we do it. Cupra console bushes at special price, PM for a very competitive quote. |
| Thanks for the quick response, i'll take it to skoda tomorrow, Will it be costley?? |
| BRISKODA Staff Join Date: Oct 2002 Location: darkest Hampshire
| Are these factory fit or retro fit in the rubbing strip? I sometimes get this if it's been raining and some water is "caught" between sensor and hole it is located in, in the rubbing strip. Also if the sensor has been pushed in slightly it will detect the rubbing strip.
__________________ Adrian. |
| Briskodian Join Date: Jul 2005 Location: South UK
| Just pull the fuse and reverse like a man, with no electronic aids - The beeping is irritating anyway.
__________________ Parents: '02 Octavia 1.9TDi Me: '99 V Honda Accord Type-R |
| Factory fit.. Had a little look last night, played about with the cable and seems to work ok now??? |
| Briskodian Join Date: Feb 2007 Location: Preston, Lancs
| Same happened to me, twiddled with wires in boot and hey presto. I have already asked the question in the Superb forum, but because I've got an Octavia (2002 TDI Elegance MK1), I just noticed that my reverse parking sensor only seems to be utilising the driver's side back door tweeter and not the passenger side, is this right? |
| Skudmunki Join Date: May 2003 Location: Northwest
| this is a very common defect across the VAG range and as far as I know it can't be checked on Vag com as they are not part of the BUS System......prove me wrong lummox and tell me how / where in Vag Com to find them as I have one that keeps going awol when its cold
__________________ http://www.sloganizer.net/en/] ![]() Diamond Silver 54 Octy vRS Mk1, 18" TT Quattro Black / Polished rims, 225x40x18 Goodyear F1 GSD3,a Forge FMIC, Forge Eliminator DV , 4bar FPR, HID Hi/Lo Mains and fogs, LED purewhite LED Sidelights, HID Fogs, Silvervision Indicator bulbs all round, Headlight protectors... |
| There is only one speaker and its located behind the B pillar trim. The sound is not produced using any of the normal car speakers, so you get sound from one side only.
| | #10 |
| Excuse my stupidity but where is the B pillar trim located? Mine is definitely coming from the tweeter in the back driver's side door. They are disconneted from the stereo for the sole purpose of hearing the parking sensor! Seems a bit of a waste to me. Thanks in advance |
| | #11 |
| Briskodian Join Date: Apr 2006 Location: Sheffield
| the B pillar is the where the front passenger seat belts are located. There is a separated speaker for them in there (trust me i fitted my own) and with it being close to the tweeter you think its coming from there when its not |
| | #12 |
| I heard they disconnected the tweeters in the door for parking sensor as my tweeters don't work with the car stereo, could be another issue... ![]() |
