This is a discussion on Broken rear seat belt trim on rear shelf within the Octavia I forums, part of the Skoda Model Discussion Area category; I'm trying to replace the off side rear shelf on my Octy Hatch, because it's broken and the parcel shelf ...
| Mile Muncher Join Date: May 2005 Location: East Midlands, UK
| I'm trying to replace the off side rear shelf on my Octy Hatch, because it's broken and the parcel shelf keeps falling off it. I've undone all the bolts, and undone the seat belt bolts top and bottom, but I can't get the seat belt through the shelf. There's a square plastic cover the seat belt feeds through. It sits on the rear trim but appears to actually be attached to the inertia reel underneath. Haynes said "prise it off", so I did and now I've snapped it. ![]() Most of it is still stuck to the inertial reel and won't budge. The reel won't come free until this top piece is removed. I can probably stick the two pieces back together, but my question is: how on earth do you remove it? Is there a lug I've missed, or does it just slide off with immense force? Grrrr J
__________________ Red Octavia Mk1 TDi with added: OEM Cruise Control, OEM Navigation and OEM Full-Maxidot dash (finally fitted). Nearly 160,000 miles on the clock and counting! |
| | #2 | |
| Quote:
![]() Sorry, I genuinely don't have a clue, but I'd guess you could pic a new one up from a breakers.
__________________ Cars make CO2 and trees absorb CO2. By driving your car you're feeding a tree and helping the environment. | |
| Well, I took the side trim and the inertia reel off together, and then the seat belt cap thingie slid off - more forwards than straight up as the reel was actually at quite an angle. Have put it all back together again with the broken one on, but it's looser now so it should come off easier. Have got a replacement coming from SkoParts for about £4. J
