39,368 Members 1,486,589 Posts
Bump starting
This is a discussion on Bump starting within the Octavia I forums, part of the Skoda Model Discussion Area category; I had to bump start my Octy the other day after leaving a portable fridge plugged in overnight. It didn't ...
Old 13-08-2008, 02:19   #1
4x4 Action
will_'s Avatar
Post Bump starting
I had to bump start my Octy the other day after leaving a portable fridge plugged in overnight. It didn't go quite as expected so I'm posting my findings in case it's useful to anyone else.
A friend and I first bumped it in second gear and the engine started but just ticked over slightly lumpily. None of the dashboard dials twitched (not even the rev counter), the alternator and airbag lights were on, and pressing the throttle had no effect.
I remember hearing once that alternators need "spinning up" to a certain speed before they start "working" (i.e. charging), and I guess we hadn't got it going fast enough. We still had clutch control so we gingerly turned the car around and accelerated up through first and second, into third - luckily it was a long car park! Once there, doing about 25mph, I dropped it back into first and everything sprung into life.
Weird, huh!
will_ is offline
Old 13-08-2008, 09:07   #2
cjb
Re: Bump starting
Probably the battery voltage was very low at first.
-- Chris
The Devil may care, but I don't mind.
cjb is offline
Old 13-08-2008, 12:09   #3
KenONeill's Avatar
Members Car: Octavia TDi110
Re: Bump starting
It's actually not recommended to bump start any car with a catalytic convertor, because when they first fire you get a slug of unburnt fuel past the lambda and cat, and it's possible for that to blow the cat.
KenONeill is online now
Old 13-08-2008, 12:09   #4
Re: Bump starting
Strange that - I did exactly the same thing last week - (Monday night/Tuesday morning) so it would have been very useful to me last week.
Fortunately the guy on the reception desk at the Premier Inn in Folkstone, allowed me to jump start mine of his car, and I still get to the Channel Tunnel on time.
By the way, is it possible to bump start deisels? I didn't try, as there wasn't enough room.
AndrewTait is offline
Old 13-08-2008, 13:16   #5
KenONeill's Avatar
Re: Bump starting
I've never tried to bump a diesel; I suspect it might not be possible on a cold engine because they rely on achieving a certain combustion chamber temperature to get the fire going.
Old 13-08-2008, 13:40   #6
Octavia Vrs!'s Avatar
Members Car:
Re: Bump starting
I've bump started an astra deisel from cold a couple of times - its hard work, the first time as soon as the driver lifted the clutch I thought she'd pressed the brake peddle. The compression is so high get it rolling at a good speed first! Must admit I didn't know about CAT damage but if your in a pickle it's worth the slight risk IMHO.
There's nothing like seeing feathers going in the opposite direction to the bird!
Octavia Vrs! is offline
Old 13-08-2008, 13:46   #7
mello in yello
postmanpat's Avatar
Members Car: fabia vRS/ octavia vRS
Re: Bump starting
Bump started LDV deisals loads of times, just make sure your not behind the exhaust when they fire up
Originally Posted by Emily-Elizabeth
Sperm donership: It is not like giving blood, it is tossing away...............
Postmanpats car Fabia vRS Zennons, ESP, autochanger, 3rd headrest, heated seats, cruise control
SWMBO Octy Mk2 vS maxidot, duel zone wotsit, cruise, parking sensors, 18" alloys
postmanpat is offline
Old 13-08-2008, 16:22   #8
RichieVRS's Avatar
Members Car: Skoda Octavia Vrs Mk1
Re: Bump starting
Agree
RichieVRS is offline
Old 13-08-2008, 18:08   #9
Banana-Man's Avatar
Members Car: Octavia RS
Re: Bump starting
With the ignition on it should be possible to push start any diesel, as long as the glow plugs heat up. Diesels do not rely on combustion chamber temp really - the fuel and air is combusted under pressure on the power stroke of the engine not from ignition spark spark like gas cars.
The only danger jumping the car from under the hood on the battery is blowing fuses? Pushing it is OK because there is no serge in electrical energy
WOW GUYS!!!! look at all my 5 fantastic mods: Green valve caps on each wheel
Banana-Man is offline
Old 13-08-2008, 18:46   #10
richardsfavorit's Avatar
Re: Bump starting
I woudn't think it warm if you bump started once or twice. I did with my Felicia and it didn't harm the emissions!
Skoda Octavia 1.6 Ambiente 17" Alloys, vRS spoiler, clear lights
richardsfavorit is offline
Old 18-08-2008, 22:18   #11
ian110's Avatar
Members Car: Octavia GLX TDi 1999
Re: Bump starting
Ahh LDV minibusses and their interior lights that flatten a battery in an hour. It is possible to bump start a overladen minibus on a flat car park with enough people pushing. The trick is to use a high gear such as 4th and lift the clutch at running speed but drop the clutch again before it stalls. With practice it is easy!
ian110 is offline
Similar Threads
Little Bump dibbley Octavia II 1 03-02-2008 22:08
Yet another bump RADIOTWO Off Topic and Chit Chat 1 06-07-2007 14:51
Bump..... bobz The Roadside Hotel 8 24-04-2006 22:24
Bump Starting yashicamat Fabia I 6 07-12-2005 13:29
Little bump William Off Topic and Chit Chat 9 17-11-2003 19:35
