This is a discussion on Cage mod on octy vRS within the Octavia I forums, part of the Skoda Model Discussion Area category; Anyone done it????? I had ago the other day and I can safely say it works. I wouldn't go so ...
| Why So Serious Join Date: Jan 2006 Location: "What" ...What ain't no god damn country
Members Car: a car Thanks: 271
| Cage mod on octy vRS Anyone done it????? I had ago the other day and I can safely say it works. I wouldn't go so far as to say "oohhh it's much faster" or anything like that but deffo makes the car smoother and I find I need less gas when taking it easy. For £5 its definately worth a shot |
| Briskodian Join Date: Aug 2006 Location: East Lothian
Members Car: Octavia vrs Thanks: 17
| Re: Cage mod on octy vRS Seems you are the last to try this,there was a post a few months back.Better late than never though.
__________________ Diamond silver octavia vRS,xenons,Jetex downpipe with sports cat,Jetex cat back system,Green panel filter,Forge i pro remap,Forge 007 dv,Milotec bumper grills,TT arch vent mod. |
| Briskodian Join Date: Aug 2006 Location: Liverpool
Members Car: Octavia vRS Thanks: 12
| Re: Cage mod on octy vRS I havent!
__________________ 2001 Rally Red Octavia vRS...remap complete Whiteline rear ARB, Superpro dogbone bush - 225/45/17 Goodyear Eagle F1 Aysmmetrics and lots of V-Power!Smiles all 'round |
| Briskodian Join Date: Jul 2006 Location: Cleveland
Members Car: Passat Sport TDi Thanks: 205
| Re: Cage mod on octy vRS Nor me. Sounds like a load of old b******s to me, but since there are so many people saying they have good results I might try it and prove myself wrong ![]() |
| | #5 | |
| Re: Cage mod on octy vRS Quote:
| Re: Cage mod on octy vRS Never said i had done it though, which i hav'nt.
| Hardcore Join Date: Feb 2006 Location: Bahrain
Members Car: Fabia vRS Thanks: 200
| Re: Cage mod on octy vRS try it - if it doesn't work - flame me, lol!! Cheerio Bas
__________________ Fab vRS - Black Magic - PD160 intake - Forge FMIC - colour coded front grille -SLC Splitter - K&N Airfilter -SEAT Strutbrace - Jabba ARB - IC Waterspray (need to wire it in!) - 312mm TT brakes - Eibach Springs - Skoda Reversing sensors - Devonutopia Tuning (tm) Custom Exhaust (2 1/4" straight pipe) - Short shifter mod- 5 brake light mod - Helix Steel SMF + Organic Clutch + pressure plate - Peloquin LSD - TD stage 2 Hybrid - Washbrook remapped ECU - Uprated injectors - Cupra bushes -Poly-filled dogbone - Allard racepipe - Pirelli Dragons - Forge Rear Strutbrace - DIY SS upper boostpipe delete -Koni FSD's - elephant pipe CCV mod |
| Briskodian | Re: Cage mod on octy vRS I did it, not sure if I found a difference but figured it can't be a bad thing. It's recommend that you use contact cleaner BEFORE applying the grease tho.... For £5 it can only preserve the connections. I think this is most popular on the fabia vRS which doesn't have the gold connections? As far as I'm aware the octavia vRS does though. |
| Need more power Join Date: Feb 2007 Location: Driffield, Good old yorkshire
Members Car: octavia VRS Thanks: 54
| Re: Cage mod on octy vRS I never really saw much difference either, i did most of the connectors too. I suppose if i were really looking i might have found it running a little smoother when driving off from cold.
__________________ Regards Martin Turbo back blueflame exhaust |
| | #10 |
| Briskodian Join Date: Aug 2006 Location: Watford
Members Car: Mondeo 2.2TDCI Thanks: 21
| Re: Cage mod on octy vRS Mine is half done ![]()
__________________ Octavia VRs ***SOLD*** The futures somkey! The futures diesel ![]() |
| | #11 |
| Re: Cage mod on octy vRS So, does anyone know why it's called the 'cage mod'?? Seems a bit random ![]() |
| | #12 |
Members Car: Fiat Panda Thanks: 15
| Re: Cage mod on octy vRS I seem to remember it was down to the name of the chap who decided to do it, but could be wrong. As said above, if you have gold plated contacts on the MAF you'll probably not see a big difference as these don't tend to corrode as much. Chris
| | #13 | |
| Briskodian Join Date: Nov 2004 Location: Leighton Buzzard
Members Car: Fabia vRS Thanks: 10
Worth noting that this isn't a performance mod, rather it resolves a problem (lumpy/lurchy throttle response). As chap with brand new Octi TFSi discovered. Oh, and it works | |
| | #14 |
| Not anymore Join Date: Oct 2007 Location: Bournemouth
Members Car: Octavia TDi 2006 Thanks: 107
| Re: Cage mod on octy vRS What is it and where do you get it from?
__________________ Car now: 56 Octavia MK2 1.9TDi Ambiente-Debadged-Metallic Flamenco Red DMF Reqiured soon ![]() Previous: 06 Octavia Mk1 1.9TDi Classic with + pack-Diamond Silver Sadly missed: 97 Nissan Primera 2.0TDi SLX- Red Paul ![]() I only live for GTA IV |
| | #15 |
| Re: Cage mod on octy vRS Update: Just been reading other threads so iam well info,d about it now Will give it a try today.
| | #16 |
| Re: Cage mod on octy vRS Done mine yesterday no different but i noticed the connections are gold coloured.
| | #18 |
| Re: Cage mod on octy vRS I filled them all up several times and kept plugging/unplugging a few times as well then added more into it.Definately more than enough.
| 'Cage Mod' TFSI VRS | Johnwg | Octavia II | 6 | 13-01-2008 22:18 |
| Cage mod on vRS | Angry Dog | Octavia I | 10 | 12-12-2007 22:17 |
| Bit of a non believer... but suprised! Cage Mod and general VRS big up! | psycho sport | Fabia I | 35 | 11-12-2007 13:30 |
| Cage mod - anyone tried this? | JRHartley | Maintenance & Performance | 56 | 02-12-2007 20:59 |
| Fabia vRS Hamster Cage Mod | Josh_PoloGTi | Fabia I | 103 | 17-05-2005 18:07 |
