39,396 Members 1,487,240 Posts
For a cambelt change should I replace the hydraulic damper as well. opinions please??
This is a discussion on For a cambelt change should I replace the hydraulic damper as well. opinions please?? within the Octavia I forums, part of the Skoda Model Discussion Area category; Hi all, When doing the cambelt/waterpump change should I replace the hydraulic damper at the same time?? Is this the ...
Old 25-01-2008, 08:56   #1
Members Car: Octavia MK1 vRS
Question For a cambelt change should I replace the hydraulic damper as well. opinions please??
Hi all,
When doing the cambelt/waterpump change should I replace the hydraulic damper at the same time?? Is this the normal proceedure?
If yes, where do I get one from??
Thanks again!!!
Newbie Rob
03 Black Magic Octavia vRS . . . . LOVE IT!!
motoxrob is offline
Old 25-01-2008, 09:30   #2
VRSPhil's Avatar
Members Car: Passat Sport TDi
Re: For a cambelt change should I replace the hydraulic damper as well. opinions plea
Yes. They're a common cause of failure, the seal dies which allows the oil to leak out, resulting in a loss of tension which lets the belt skip.... not good at all. It's a false economy not to IMHO.
'54 Passat PD130 Sport... 55mpg
Octavia vRS WRC - Gone but not forgotten!
VRSPhil is offline
Old 25-01-2008, 10:11   #3
Cheers VRSphil,
Will anyone confirm for me that
part no: 13134 is the correct part from GSF.
I'm only asking as it doesn't state that it will fit the engine code AUQ (vRS).
Newbie Rob
motoxrob is offline
Old 25-01-2008, 15:58   #4
pdhealy's Avatar
Members Car: Skoda Octavia vRS
Originally Posted by motoxrob View Post
Cheers VRSphil,
I spoke to a guy int GSF's office in Dublin earlier today about this exact part. Part No. 13134 is the part you are looking for - although it doesn't say it on the web, I was told that there are about 15 different engine codes it is used on, incl AUQ.
Dear Lord.. The gods have been good to me. For the first time in my life,
everything is absolutely perfect just the way it is. So here's the deal: You
freeze everything the way it is, and I won't ask for anything more. If that
is OK, please give me absolutely no sign. OK, deal.
pdhealy is offline
Similar Threads
When to change cambelt and what exactly needs doing please Aaquil Octavia I 8 19-12-2007 11:15
Does cambelt/waterpump change necessitate an oil change? The Ors Octavia I 3 21-12-2006 19:08
Cambelt Change drumbold Octavia I 4 26-10-2006 15:59
Is it worth combining a water pump change with a cambelt change? DGW Octavia I 34 20-09-2006 19:16
Cambelt- when to change? MARTYNG Fabia I 31 17-02-2006 00:31
