39,396 Members 1,487,241 Posts
Cambelt Change
This is a discussion on Cambelt Change within the Octavia I forums, part of the Skoda Model Discussion Area category; My Octy has only 22,345 miles on the clock, but is only four years, six month old. Would it be ...
Old 23-01-2008, 18:42   #1
hussarman's Avatar
Members Car: Railton Straight 8
Cambelt Change
Would it be wise to change the cambelt now or wait for the car to reach the 60,000 mark.
hussarman is offline
Old 23-01-2008, 20:04   #2
Legend!!
SCVRS's Avatar
Re: Cambelt Change
I would change it now. 4 years is a good point to change the cambelt even though it has low mileage.
I would rather pay out £350 or less for a cambelt change than have to pay for repairs on a knackered engine!! That could be MUCH more expensive.
Silver Mk1 Octavia vRS with Green Panel Filter
Silver Mk2 Octavia vRS TDi pd170 with Green Panel Filter
Playstation 3 network id : SCVRS (feel free to add me)
Support Briskoda! Join Freedom........You turn green!!!!
SCVRS is offline
Old 23-01-2008, 20:32   #3
Members Car: 2002 octavia tdi
Re: Cambelt Change
when u change the cam belt ask them to look at the water pump its part of the cam belt system if it needs replaceing then its only abot £40 unlike if u do it later will cost u same as a cam belt to get done
welshman504 is offline
Old 23-01-2008, 21:13   #4
Members Car:
Re: Cambelt Change
Hi, I'd get it done at it's next service. The issue with the water pump is that the impeller is plastic & can fail due to the temperature cycling it is exposed to. Failure would normally result in loss of water circulation then overheating & head gasket if you don't notice it in time but sometimes pump can jam giving same damage as broken timing belt - ouch! I had my Mk1 vRS changed along with the cambelt kit after 5 years when I read about water pump failures & the impeller on the old one had a crack in it. Note - OE replacements still have plastic impellers but I was advised to stick with these & replace the pump along with the cambelt every time. There are alternative water pumps with cast impellers available. I hope this helps.
Cheers wuzz
Wuzz is offline
Old 23-01-2008, 21:16   #5
BRISKODA Staff
mannyo's Avatar
Re: Cambelt Change
Get the belt changed, its 4 years OR 60k miles, whichever occurs first. Also as said already get the water pump changed at the same time. DGW had his belt and pump changed at 4 years and 28K miles and the water pump was in small pieces when removed from the engine.
Manny
2005 Octavia 2.0TDi Elegance combi
my skoda website http://www.octaviars.co.uk
Join the briskoda.net folding team click Here for more info
mannyo is offline
Old 24-01-2008, 12:46   #6
hussarman's Avatar
Re: Cambelt Change
Many thanks for the words of wisdom.
Old 24-01-2008, 13:34   #7
KenONeill's Avatar
Members Car: Octavia TDi110
Re: Cambelt Change
As previous replies, but the waterpump is less critical if the car's a diesel, since they run cooler.
KenONeill is offline
Old 24-01-2008, 15:06   #8
Members Car: .
Re: Cambelt Change
I'd recommend getting a water pump with the metal impeller in any event as I believe they are a similar price.
simonlb is offline
Old 25-01-2008, 11:08   #9
hussarman's Avatar
Re: Cambelt Change
For what it's worth.
Just booked the machine into Frank Follett Motors at London Colney, independant VAG garage.Priced confirmed was £338.50p which includes new cam belt, alternator belt, tensioner, idler wheel, metal water pump and anti freeze.
Old 25-01-2008, 13:15   #10
Members Car: Octy VRS
Re: Cambelt Change
Hi mate, all of what your having done I just had done at Impossible performance for 252 pounds!
Mods-
ABD racing CAI --- ABD racing TIP --- Forge DV --- Blue flame full sytem --- Koni FSD's --- Bosch aero twins --- Fuel 4 5 Stud - 18" --- Milotek 3 grill set --- Milotek bonnet lifters --- Eibach springs --- Impossible Performance custom remap
'Impossible' is Nothing
Ender is offline
Similar Threads
Cambelt Change fiendish fly Maintenance & Performance 14 01-08-2007 12:08
cambelt change graememac Maintenance & Performance 7 15-07-2007 21:45
Does cambelt/waterpump change necessitate an oil change? The Ors Octavia I 3 21-12-2006 19:08
Is it worth combining a water pump change with a cambelt change? DGW Octavia I 34 20-09-2006 19:16
