This is a discussion on Cambelt - Use Genuine? within the Octavia I forums, part of the Skoda Model Discussion Area category; Getting quotes for cambelt on my octy and quotes obviously vary between using a main Skoda dealer and a specialist. ...
| Briskodian | Cambelt - Use Genuine? Getting quotes for cambelt on my octy and quotes obviously vary between using a main Skoda dealer and a specialist. I've found that for cambelt & waterpump to difference can be up to £100-140...quite a bit - 6 months tax! The specialist uses parts from people like swedish & german parts/europarts etc and the parts have the same supplier marking, but I'm hesitant about using non skoda branded parts (ie those that would be used at a dealer). Should I worry about using Genuine or non Genuine SKoda parts? |
Members Car: Black Magic Fabia vRS Thanks: 346
| Re: Cambelt - Use Genuine? If they're made by the same supplier, I wouldn't worry personally. I've been happy non-OEM supplier parts in the past as well as OEM supplier parts like the cambelt you mention, but I'd never get them for anything with any safety or reliability significance... IIRC, the specialist where I used to get my car done had a big book of approved parts for VAG cars - I've never looked in it, but there's an implication there that the parts are suitable and of comparable quality even if they've not got a VAG logo on...
__________________ |
Members Car: Fabia 2.0/Felicia Thanks: 48
| Re: Cambelt - Use Genuine? vw use belts which are manufactured by Gates Auomaster. you can normally buy these from any decent motor factors (same belts but without vw part number on it) at about half the price |
| Briskodian Join Date: Jun 2006
Members Car: Octavia 1.9 TDI 110 Thanks: 17
| Re: Cambelt - Use Genuine? WARNING! I had a Cambelt fitted at 55K and it went at 76k - not a genuine skoda one - and a costly exercise as the garage (local) were not in businesa anymore so I couldnt sue their arses! My advice - go to a main dealer where the work will be guaranteed - Just my personal experience and I bet loads of you out there have got non genuine skoda belts that have gone on for miles with no probs Last edited by Blanes; 30-05-2007 at 21:07. |
| Briskodian | Re: Cambelt - Use Genuine? I think what you have to be very careful of is that whoever fits it, fits the whole kit including tensioners and not just the belt. I think this will be where blanes problem comes from as a belt coming off almost certainly means it either snapped or lost tension. I would say the GSF parts made by the same people as VAGs as a full kit inc tensioners, and a new water pump while you are at it would be fine. I would probably use a decent local indy. When I was looking at it for my car JKM were quoting a smidge over £300 using genuine parts and a water pump, against a dealer asking for more like £450.
Members Car: Octavia 1.8T 4X4 Estate & Fabia vRS Thanks: 51
| Re: Cambelt - Use Genuine? The advantages of having the work done by a Skoda dealer are that all work carried out is warranted against faulty workmanship for a period of 12 months or 12,000 miles, whichever comes first, plus all genuine parts used have a 12-month warranty from date of installation or sale.
Members Car: Octavia TDi110 Thanks: 63
| Re: Cambelt - Use Genuine? As a general point, IME GSF (when they supply exactly what you ordered) generally supply <car maker> OEM parts in boxes whch say <OEM> rather than <car maker>. |
| Site Sponsor Join Date: Apr 2006 Location: brighton
Members Car: octavia vrs 03 Thanks: 0
| Re: Cambelt - Use Genuine? i'd go genuine cam belt gsf water pump (as they have a metal impeller) thats what we did with the octy! no problems yet!
| Briskodian Join Date: Jun 2005 Location: South UK
Members Car: Golf GTI, swmbo Octy VRS Thanks: 0
| Re: Cambelt - Use Genuine? Thats what I am doing, gsf water pump, genuine belt, fitted at local independent. £100 less than local dealer. |
| | #10 |
| Briskodian Join Date: Jun 2005 Location: NW Kent
Members Car: Metalic Black 1.8T 4x4 Estate Thanks: 9
| Re: Cambelt - Use Genuine? Mines booked in tomorrow. Skoda Motoline - £257.odd. inc VAT. Water pump being fitted at the same time for just the cost of the pump (35 squids IIRC).
__________________ Deli G ,,,, leader of the Peckham Massif! KW Coilovers fitted, Forge TIP fitted, KK fitted, Blueflame full system fitted, CAI fitted, Forge 007 D/V fitted, PBVH4 fitted, Forge adjustable rear tie bars fitted, FMIC fitted, 312's fitted, Tints fitted. Was that a 4x4 Skoda??? It's IMPOSSIBLE! 197.2 BHP & 263.1Nm |
| | #11 |
| Briskodian | Re: Cambelt - Use Genuine? [quote=cheezemonkhai;927682]I think what you have to be very careful of is that whoever fits it, fits the whole kit including tensioners and not just the belt. I think this will be where blanes problem comes from as a belt coming off almost certainly means it either snapped or lost tension. Agree entirely. I got mine done at a local independent..12000 miles later the tensioner gave up..of course they hadn't changed it. To be fair I hadn't known that it needed to be done...if only I'd found Briskoda before then I'd be £550 richer, after having to have the belt, tensioners, rollers all changed. ![]() An expensive exercise. |
| | #12 | |
| Re: Cambelt - Use Genuine? Quote:
__________________ Deli G ,,,, leader of the Peckham Massif! KW Coilovers fitted, Forge TIP fitted, KK fitted, Blueflame full system fitted, CAI fitted, Forge 007 D/V fitted, PBVH4 fitted, Forge adjustable rear tie bars fitted, FMIC fitted, 312's fitted, Tints fitted. Was that a 4x4 Skoda??? It's IMPOSSIBLE! 197.2 BHP & 263.1Nm | |
| | #13 |
| £2100 Thats how much I'm being charged for a new head + valves+ Cambelt - VAT and Labour - Just heard today. Yeah apparently it was a non genuine belt - tensioners were changed - but somehow it came loose and came off - Can't believe the cost - ![]() What a sh*t! There goes my savings and the chance to buy a new motor anytime soon! I've had loads of cambelts done in local garages and they have all been fine - Just this time Sods law kicked in - Make sure if you have one done its a reputable "GOOD" local garage I might e-mail skoda UK and grovel for them to pay a little towards it - you never know! Live and learn...... |
| | #14 |
| Re: Cambelt - Use Genuine? Life is Crape at times mate,
| | #15 |
| Re: Cambelt - Use Genuine? |
| | #16 |
| Re: Cambelt - Use Genuine? Yes, but "genuine parts" means the plastic water pump impeller. Having seen the state of one that was removed (in several pieces), as someone posted on here recently, there are benefits of having it done at an independent (but one that knows what they're doing!) who'll fit the non-standard metal impeller... You pays your money and takes your choice... ![]()
| | #17 |
| Briskodian Join Date: Jun 2004 Location: in the great north west
Members Car: octavia Thanks: 2
| Re: Cambelt - Use Genuine? I know a few years ago on VW engines that there was so little difference in cost on the genuine and non that it was worth buying the puker one for the markings on the cambelt. not sure if it is still the same now |
| | #18 |
| Briskodian | Re: Cambelt - Use Genuine? You might be able to go to a breakers and get a second hand engine for a lot less money than that.
| | #19 |
| Re: Cambelt - Use Genuine? Got my water pump from GSF (£21.00) yesterday, the metal impeller pump has now been phased out in favor of a new improved plastic one. Skoda (£35.00) also confirmed that the new plastic pump has been improved!
