Changed my brake fluid and now its broken
This is a discussion on Changed my brake fluid and now its broken within the Octavia I forums, part of the Skoda Model Discussion Area category; Ok... today I swapped my clutch slave cylinder over as I believed it was leaking (turned out to be the ...
Old 04-06-2006, 20:22   #1
mbames's Avatar
Question Changed my brake fluid and now its broken
Ok... today I swapped my clutch slave cylinder over as I believed it was leaking (turned out to be the fitting at the end of the hydraulic pipe instead (so not resolved that :-( )
I also took the chance to change the brake fluid (with pressure kit). I followed the instructions as per Mr Haynes for a full fluid change. ie. bled A and B, and then brakes in the correct order (both fronts at the same time, then both backs, and then around each one in order). Also did the clutch.
With out the engine running everything seems fine - pedal nice and firm etc. Started the car, and the pedal went straight to the floor, a few pumps and the stiffness returned (air in the system?)
So I bled the whole thing twice more (using a pressure kit) and still just the same. I wondered if it was because the car knew I was not moving, so I took it out for a test drive. Pedal was firmer, but still sinks all the way down when pressed down hard. Also the ABS fails to cut in - all.
When I got back, I tried holding then engine revs (say at 2000rpm) and then pressing the brake. This caused the revs to drop down to tick over. Upon releasing the pedal the revs returned to what they should be. I tried this, as did my dad and I am sure we don't both have wonky feet!!
Any ideas what is going on?
mbames is offline
Old 04-06-2006, 20:26   #2
Cupra Bush King
Lummox's Avatar
Images: 2
Re: Changed my brake fluid and now its broken
If the pedal pumps up you have air in the system. You didnt let the level get really low did you?
Unit 18 Automotive Services
www.unit18.co.uk
Lummox is offline
Old 04-06-2006, 20:52   #3
mbames's Avatar
Yes - drained all the old fluid out and replaced with new; but have then completed three full bleeds.
mbames is offline
Old 04-06-2006, 20:55   #4
Cupra Bush King
Lummox's Avatar
Images: 2
Why would you drain all the old fluid out? You should just flush it through.
If you have emptied the ABS unit, this can only be bled properly with diagnostic equipment to open the solenoids up.
You may get away with bleeding the master cylinder out first, there are either one or two bleed nipples on the side.
www.unit18.co.uk
Lummox is offline
Old 04-06-2006, 21:06   #5
mbames's Avatar
I have bled primary and secondary values on the master cyclinder with no joy.
I haven't got VAG-COM with me at the moment, but can I do the solenoid reset with this at home - or is it a dealer job?
mbames is offline
Old 04-06-2006, 21:08   #6
Cupra Bush King
Lummox's Avatar
Images: 2
If the master cylinder wont help then there is air in the ABS unit.
Either get yourself VAG COM or its to the dealer with you.
Could be an expensive mistake.
www.unit18.co.uk
Lummox is offline
Old 04-06-2006, 21:17   #7
mbames's Avatar
What steps do I need to take through VAG-COM? Thank you very much :-)
Cheers,
Matt
mbames is offline
Old 04-06-2006, 21:25   #8
Cupra Bush King
Lummox's Avatar
Images: 2
I dont know to be honest, I use dealer equipment to do it. Does take a fair while though and alot of fluid.
www.unit18.co.uk
Lummox is offline
Old 04-06-2006, 21:39   #9
Briskoda Staff
VRStu's Avatar
This may help you
http://www.ross-tech.com/vag-com/cars/absbleeding.html
Stu
VRStu is offline
Old 04-06-2006, 21:51   #10
mbames's Avatar
Cool - thanks. Just need to wait for my gf to get home and turn on my server so I can grab my software from there for use on my parents PC.
Looks like I won't be in work tomorrow morning!
Cheers all - will report back tomorrow as to how I get on!
(mental note to self: get a laptop to keep in the car!)
mbames is offline
Old 04-06-2006, 22:27   #11
Briskoda Staff
VRStu's Avatar
Should that not read -
Mental note to self - don't drain out all the brake fluid as air gets in.
Stu
VRStu is offline
Old 05-06-2006, 21:35   #12
mbames's Avatar
yes... probably! I had to give in after a whole day of trying to get the air out. Booked into the dealers for Thursday.
mbames is offline
