This is a discussion on Changing Spark Plugs. within the Octavia I forums, part of the Skoda Model Discussion Area category; For what it's worth. Today I watched a professional change four spark plugs on a Octavia 2003 1.6 Petrol engine. ...
| Briskodian Join Date: Sep 2007 Location: Essex
| For what it's worth. Today I watched a professional change four spark plugs on a Octavia 2003 1.6 Petrol engine. Absolutely amazing, job completed in seventeen minuets, to me it seemed tantamount to climbing Everest. |
| Briskodian Join Date: Jun 2007 Location: Cornwall
| It's a pretty easy job once you've done it once. Whip coil connectors off Whip coil packs out Take out old spark plugs Whack the new ones in (hand tight, then with a torque wrench) Put coil packs back in Reconnect. If I can do it, anyone can.... ![]()
__________________ Octy vRS mk1; APR Stage 1, Forge 007p DV, THS TIP, Honda s2000 aerial, seat cupra front splitter, MAS alloy center caps, alpine CDE-9871R, infinity 6010cs, Jbl 75.4 and 10" sub. Pug 205 gti; mi16 200bhp/tonne ![]() |
| Why So Serious Join Date: Jan 2006 Location: "What" ...What ain't no god damn coutry
| Same applies here ![]() ![]() I rekcon I could do it quicker than 17 minutes as well ![]() |
| | #4 | |
| Hairy Yeti Join Date: Sep 2003 Location: Newport Pagnell
| Quote:
Plugs are buried under the inlet manifold which wraps over the cylinder head. 2+3 are a pain, its a knack to change them.
__________________ Unit 18 now open Servicing, repairs, modifications you name it we do it. Cupra console bushes at special price, PM for a very competitive quote. | |
| | #5 | |
| Quote:
Big up the op's tech | |
| | #6 | |
| Quote:
__________________ Octy vRS mk1; APR Stage 1, Forge 007p DV, THS TIP, Honda s2000 aerial, seat cupra front splitter, MAS alloy center caps, alpine CDE-9871R, infinity 6010cs, Jbl 75.4 and 10" sub. Pug 205 gti; mi16 200bhp/tonne ![]() | |
| ECUless Join Date: Mar 2005
| Getting the plug leads off intact is also a skill with these engines. |
| Briskodian Join Date: Feb 2008
| While we on the subject. Should ther be a cover about 50 mm x 150mm over the coils? I think mine is missing, I can see the connection when I lift the bonnet 1.4 petrol |
| 16v I guess then, depends on which engine and year.
| | #10 |
| Messrs Lummox and Fordfan have got it right. No. 2 & 3 plugs buried under the inlet maifold, the mechanic did mention take extreme care with the HT leads which are prone to become brittle and break. |
| | #11 |
| Yeah, I was thinking "how hard is moving the coil packs on that engine?", cos I've changed plugs on a double-ended coil engine faster than that (and even checked the gaps were right when doing it). |
| | #12 |
| Briskodian Join Date: May 2007 Location: .
| Spark plugs? I've forgotten what they look like! ![]() From what I can gather, the Vauxhall 3-litre V6 is a pain to do them on Cavaliers and Vectra's as you have to remove the inlet manifold from one of the cylinder banks to get to the plugs. ![]() |
| | #13 |
| Briskodian Join Date: Apr 2006 Location: Wexford, Ireland
| | #14 | |
| Quote:
Yup, my old V6.... ![]() 2.5L
| | #15 | |
| Quote:
sparks at back on engine under the inlet manifold and the single point injector with the throttle wire running over them and breather pipes all in the way too. That plus the air cleaner needing to come off too so even see that lot. 2 was a real PITA. Why people don't think about this when designing engines etc I'll never know.
__________________ Cars make CO2 and trees absorb CO2. By driving your car you're feeding a tree and helping the environment. | |
