39,456 Members 1,489,919 Posts
Climate control/temp readout problem
This is a discussion on Climate control/temp readout problem within the Octavia I forums, part of the Skoda Model Discussion Area category; Whenever i turn the ignition on the climate control panel lights up everything and diagnostic shows on the top.....for about ...
Old 18-12-2007, 19:18   #1
Members Car:
Whenever i turn the ignition on the climate control panel lights up everything and diagnostic shows on the top.....for about 6 seconds. It then changes and works as normal
BUT
The temp is always showing -8 and it also shows that on the OBC... -8
Also....sometimes the climate panel doesnt light up
Any ideas peeps????????
TIFF is offline
Old 18-12-2007, 19:57   #2
Members Car:
Re: Climate control/temp readout problem
If it's on both it might be a fault with the temp sensor.
nbr_uk is offline
Old 18-12-2007, 19:59   #3
Members Car:
where abouts are the temp sensors located???
TIFF is offline
Old 19-12-2007, 00:40   #4
Bad man
Members Car: Skoda Octavia vRS
Tiff,
I believe it is under the scuttle panel on the drivers side of the car.
Regards,
Mike
Proud owner of a Remapped Red Octavia vRS
Never argue with an idiot - they will only beat you with experience.
Angry Dog is offline
Old 19-12-2007, 09:59   #5
Members Car:
Cheers
Any idea what they look like
TIFF is offline
Old 19-12-2007, 10:47   #6
VRSPhil's Avatar
Members Car: Passat Sport TDi
It's behind the N/S bumper grille on aq vRS. Pull the grille out and you'll see it screwed to the bumper. I can't see why the sensor would cause the display to not light or go into diagnostic mode, though. Any chance of getting VAG-COM plugged in to see what it says?
'54 Passat PD130 Sport... 55mpg
Octavia vRS WRC - Gone but not forgotten!
VRSPhil is offline
Old 19-12-2007, 10:48   #7
Bad man
Really? My Auto data again suggested other wise, unless its on about a different temperature sensor?
Regards,
Mike
Old 19-12-2007, 11:52   #8
VRSPhil's Avatar
Not sure what might be under the scuttle, I've had mine off and didn't see a temperature sensor. The external air temperature sensor is behind the N/S grille... I had mine off the other week.
VRSPhil is offline
Old 19-12-2007, 12:00   #9
BRISKODA Staff
mannyo's Avatar
The exterior temperature sensor is behind the nearside front bumper grill as already mentioned.
The issue may also be an internal sensor problem, there are several at different points in the front of the cabin.
Manny
2005 Octavia 2.0TDi Elegance combi
my skoda website http://www.octaviars.co.uk
Join the briskoda.net folding team click Here for more info
mannyo is offline
Old 19-12-2007, 22:40   #10
Members Car:
it is the external temp sensor i am after
TIFF is offline
Similar Threads
Climate Control problem? adge Octavia I 5 27-08-2007 20:06
Dual climate control problem octaviarsman Octavia II 7 04-06-2006 10:22
Octavia climate control minimum temp pinkpanther Octavia I 1 26-04-2006 19:16
Octy 2 Climate control problem ?? darius Octavia II 0 27-03-2005 15:04
