This is a discussion on Clutch Slipping? within the Octavia I forums, part of the Skoda Model Discussion Area category; Had my 4x4 Revo'd a couple of months ago, no problem there , but over the last week I've noticed ...
| Clutch Slipping? Had my 4x4 Revo'd a couple of months ago, no problem there , but over the last week I've noticed the clutch start to slip |
| Briskodian Join Date: Aug 2005 Location: Back in the Green
| Re: Clutch Slipping? I had the same problem with mine after I fitted a dragon digi box to it. It was quite a random thing as well, some times it wouldn't do it for ages, then all of a sudden it would slip like a bar of soap. it was worst in 5th or 6th at about 1800rpm, foot down and off goes the rev counter. Can't help re replacement but my clutch slip has gone now the box is off (temporary hiccup) which says to me the standard clutch isn't man enough for the job.
__________________ MY08 L&K: Black-Estate-Diesel-Sunset Glass-MFD2-W8 Interior light-Colour coded door strips-LED sidelights and Puddle lights-VAG-COM fettled-Lovely! SWMBO's: MY08 vRS TDI - Standard ![]() |
| Re: Clutch Slipping? No problems with mine and a Jabba remap - but still under 20,000 miles.
| Re: Clutch Slipping? Had a Jabba remap for about a week and my clutch couldn't handle the torque and began slipping big time. Got a new clutch assembly and now everything is fine |
| BRISKODA Staff Join Date: Oct 2002 Location: darkest Hampshire
| Re: Clutch Slipping? This really comes down to how you drive.....if you like traffic light racing and make the engine slog at low revs in a high gear then you are going to get clutch slip. My RS is running 300+bhp/300+Nm and all on a standard clutch....no slip. Diesel with a remap may have some clutch problems though but, if you have a custom map you can have it tuned to have the torque turned down, as it is the torque which causes the problems.
__________________ Adrian. |
| Re: Clutch Slipping? Anyone know what the maximum torque is on the TDi Octys that the gearbox/clutch can handle.
| Re: Clutch Slipping? Nothing to do with standing starts or traffic light racing just when planting right foot in 4th from 40/45 when overtaking in no particular hurry. Can be made worse if you try harder but less noticeable in lower gears. As my 4x4 is nowhere near 300bhp unless Revo normal map is a lot better than they claim (seems unlikely) there must be some other problem like an oil leak maybe. What has anyone fitted instead of the standard clutch when this happens? Cars (52 plate) only done 30k so somewhat disappointed as the only the last 2k on remap. |
| Re: Clutch Slipping? Just noticed the 300bhp one is an RS, is this a different clutch? |
| Re: Clutch Slipping? same clutch, when the clutch in my 4x4 went i replaced it with a sachs clutch and lightened G60 flywheel ![]() i give mine no end of **** and it hasn't slipped since getting it fitted(nearly two years ago i think) and it was played with by jabba over a year ago ![]()
| | #10 |
| Re: Clutch Slipping? Thanks for that. What was the damage getting that fitted or did you do it yourself? |
| | #11 |
| Re: Clutch Slipping? forget doing it yourself on a 4x4, exhaust off, prop off, then the transfer box and gearbox are very heavy. get it done by a garage ![]() skoda quoted me about £850 but i got the sachs clutch and flywheel for about £450 i think(can't really remember tbh) and fitting was another £100 by a mechanic that charged £25 an hour ![]()
| | #12 |
| Re: Clutch Slipping? That'll be popular indoors then - no dear no need for any other expensive mods just goes quicker - oops |
| | #13 |
| Re: Clutch Slipping? lol clutch's do go though, atleast with yours its slipping. on my car the bearing went which made shifting very difficult and the few miles i had to do in the car probably didn't help with the gearbox failure soon after ![]()
| | #14 |
| Re: Clutch Slipping? I noticed the clutch on mine slipped the most between 1800 and 2200 rpm, pretty much where all the torque lurks on the rev range. It's done it from 30,000 miles onwards, my has done over 95,000 now with the box off and there is no slip whatsoever. On the motorway in 6th at 65, foot to the floor = monster clutch slip lol. Its' definitely the torque thats the killer. PD130 is 310NM standard and mine was chucking out somewhere in the region of 350-360NM. Question: is the clutch on the new 2litre TDI 140 meatier than the one on the 1.9TDI 130?
| | #15 |
| Re: Clutch Slipping? we are talking about a 4x4 1.8T here not a 19TDi ![]()
| | #16 |
| Re: Clutch Slipping? Is the clutch for £480 mentioned in the Tech Guides under "If Carlsberg made Octavias etc" the Sachs one or is it different? Where are these available from? I still find it a bit odd that someone can have 300bhp and the same clutch which doesn't slip yet mine at around 200 and a bit slips at anything more than half throttle now. |
| | #17 | |
| Re: Clutch Slipping? Quote:
Most of the main tuners will do you an uprate clutch and single mass flywheel. Check out: Awesome GTi Jabbasport Impossible Performance Have you had the car from new? It may be that the clutch has just glazed over....can be deglazed by pouring some water over it...apparently. I know Jabba have done this and sorted probs for people....don't know how they go about it though. I've had my RS from new...been through a remap with additional mods..circa 230bhp...now have a big turbo and 300+bhp and 300+Nm torque.....no probs...so far.
__________________ Adrian. | |
| | #18 |
| Re: Clutch Slipping? Yes had it since new no problem until after Revoing. Not sure why it would glaze unless something got on it to start with. Think I'll take it somewhere tomorrow for a profes. opinion. |
| | #19 |
| Re: Clutch Slipping? Took car to two places first recommended the second as they didn't fancy the job and the second quoted £650 which seems a bit steep. This was for a Clarkes clutch. Anybody heard of them? Also wanted the car for 2 days which could be a problem. Any suggestions for anywhere to try near Great Yarmouth.On a seperate point why didn't the clutch slip as soon as it was done, or even on the Revo trial? |
