coolant sensor
This is a discussion on coolant sensor within the Octavia I forums, part of the Skoda Model Discussion Area category; hi anyone help whith the location of the engine coolant temperatur sensor on an octavia 1.9 tdi. is it on ...
Old 11-12-2007, 18:48   #1
coolant sensor
hi
1.9 tdi. is it on the radiator
andy01taxi is offline
Old 11-12-2007, 18:52   #2
Gizmo68's Avatar
Re: coolant sensor
The one for the temp gauge is at the back of the engine towards the gearbox. They are a common fault if the temp gauge is jumping up and down. Not easy to see, but dead easy to change - 30 second job
Gizmo68 is offline
The Following User Says Thank You to Gizmo68 For This Useful Post:
andy01taxi (11-12-2007)
Old 11-12-2007, 19:03   #3
Re: coolant sensor
i have a fault code 17664 whitch says engine coolant sensor would this be the one
Old 11-12-2007, 20:21   #4
Gizmo68's Avatar
Re: coolant sensor
Pretty sure yes, its the only one in the engine to my knowledge, when mine went i just changed it without a diagnostic check.
Simply unplug the sensor, pull the clip off, then with a stone cold engine pull the old one out (make sure the seal comes out with it) and pop the new one back in, you will loose about a cupful of coolant - a little more if the seal isn't on the old sensor.
Gizmo68 is offline
Old 11-12-2007, 21:41   #5
Re: coolant sensor
On my 110 tdi the temp sensor is on the right of the block ( looking from the front ). Disconnecting the sensor connecter will cause the dashboard gauge to read 0 and the glow plug light (and plugs) to remain on. havn't had to change it yet.
sam95 is offline
Old 12-12-2007, 10:18   #6
Re: coolant sensor
got it sorted lads thanks for the help
Similar Threads
Coolant Temperature Sensor scoobydoobry Octavia I 5 19-11-2007 12:35
coolant sensor (110TDi) mbames Octavia I 5 18-09-2006 13:49
Coolant sensor Octavia Red Octavia I 4 01-06-2006 20:04
coolant temp sensor fatty5000 Diagnostics & VAG-COM 21 06-04-2006 22:50
Coolant Temperature Sensor pittVRS Maintenance & Performance 7 26-01-2005 20:53
