This is a discussion on Could be the MAF? within the Octavia I forums, part of the Skoda Model Discussion Area category; Hay Guy’s Could be the MAF? The car is Octavia VRS standard with 25.000 miles. I feel the engine lose ...
| Briskodian Join Date: Oct 2004 Location: Madeira
| Hay Guy’s Could be the MAF?The car is Octavia VRS standard with 25.000 miles. I feel the engine lose power between 2000 to 4000 rotation. There are no errors in ECU used the Bosch diagnostic software. The work of the engine in the upper rotation sound’s strange. But in lower rotation no problem. Best regard’s A. Luís |
| Try disconnecting the MAF and driving around. If it doesn't make a difference, then it's something else. There's plenty on MAFs here, so do a search if you need to know more...
__________________ |
