Decision time ~ 120k
This is a discussion on Decision time ~ 120k within the Octavia I forums, part of the Skoda Model Discussion Area category; I've got a 1999 90bhp TDI Octavia that will soon be due it's 120k service. This is a big one, ...
Old 05-06-2007, 09:47   #1
Default Decision time ~ 120k
This is a big one, as it's both ....
a 40k service & a 60k cambelt, water pump etc
The car is totally stock at the moment,
I'm planning to keep it another year or so.
I average 30k & 60mpg+ a year, mainly m-ways.
My local dealer is amazed that it's still got the same
front pads & discs they fitted at 26k when I bought it.
(So I guess I have a fairly relaxed driving style!)
However, I would like to have a bit more uuumph without melting the engine,
it's still got the original clutch too.
... owner of a "rare" Octy II TDI Sport
(and also a couple of "common as muck" old RWD Octavias)
Next trip from Scunthorpe & Doncaster clicky
http://briskoda.net/yorkshire-skoda-...5/#post1444850
gcr31463 is offline
Old 05-06-2007, 09:49   #2
ASZ Eternal
ap0gee's Avatar
Default Re: Decision time ~ 120k
Remap?
ap0gee is offline
Old 05-06-2007, 09:51   #3
Oh yeah ...
Engine code AGR .... probably the only one on Briskoda
Gearbox code DQY
Main ECU not flash programmable through the diagnostic port.
I was thinking of more air in (Cupra intake, Green panel filter)
injectors from a 110 AHF engine or perhaps an aftermarket equivalent
then either a new ECU or an inline box
Just enough to puzzle Furby VRS drivers?
Has anyone done this on this model of engine & at this mileage?
thanks in anticipation ... Darren
gcr31463 is offline
Old 05-06-2007, 10:21   #4
Meant to say for clarity ......
This is a non PD engine with a VP37 fuel pump.
Without an ECU change / Inline box would
changing the injectors just produce more black smoke?
Or would the fuel pump not even increase the fuel flow,
as it had't been told too by the ECU?
gcr31463 is offline
Old 05-06-2007, 10:29   #5
If I have it right then you don't need remap to use the increased size of injectors. [edit] coz I got it the wrong way round ... doh
From tdiclub it appears a common trick is to replace the 10mm fuel pump with the 11mm pump from the Automatic which has the same effect as going up an injector size ... tdiclub is back up by the way ... definately check it out ... espectally the the FAQ and in particular section 6 Performance.
TDI FAQ
thephm is offline
The Following User Says Thank You to thephm For This Useful Post:
gcr31463 (05-06-2007)
Old 05-06-2007, 10:40   #6
yeah thanks again thephm
I managed to have a trawl around tdiclub & kermatdi
They all seem pretty keen on bigger nozzles.
I'm not 100% sure if I can determine which has a greater
effect on the quantity of fuel delivered, the pump or the nozzle.
I'm guessing that as there's more auto's than manual in the USA,
hence that's why they favour that swap.
gcr31463 is offline
Old 05-06-2007, 10:45   #7
Reading the FAQ the autos use a smaller nozzle and then pump more fuel for emissions reasons (at least in the US). Though with an AGR engine code I think you have an a3 platform which means the pump won't fit ... the 11mm pump was introduced in the a4 platform (note a3 and a4 are not refering to the Audi cars of the same names ) Also the 11mm pump puts more strain on the engine so I rekon it would be better going to bigger nozzles.
thephm is offline
Old 07-06-2007, 00:15   #8
Well one thing that's reassuring, no-one has shouted ....
DON'T MOD IT 120k is too old.
Spoken to a well known VAG tuner,
they suggested just a re-map,
as nozzles would be too much for the turbo.
I'm pleased they've suggested to be conservative,
rather than trying to squeeze every possible hp from the engine
(& every ££££ out of my wallet at the same time)
gcr31463 is offline
Old 07-06-2007, 00:40   #9
Nuts
anonymouse's Avatar
TBH - now is the time to swap it
Used to private-hire - last car Cavalier 1.7TD
Fine until it got to 100k or so.
Then, one thing after another would go - in 3's usually
So, you've had a good run, so far.
Trade it in, get a demo / low mileage car - and then enjoy another few years of virtually no maintainence.
"Stupidity, if left untreated, is self-correcting." - Heinlein
anonymouse is offline
Old 08-06-2007, 00:10   #10
Hmm, I had that thought myself,
however, I've been in loads of Octy mini cabs with 200k plus.
I've known some go over 400k, so it's barely run in.
Plus, I've recently had some work done on the house
& I'm spending money on the restoration projects.
So in short, I don't want to stretch the budget.
Plus in 18 months there will be Octy VRS TDIs coming off 3 year PCPs.
Although I still harbour aspirations of a 2.5 V6 TDI Superb too.
I had a look in price guide the other day,
p/x value of mine is erm half a pack of fags & a bag of crisps! Ouch!
May as well run it for another year to bring the pence per mile down!
gcr31463 is offline
Old 08-06-2007, 00:58   #11
Nuts
anonymouse's Avatar
Yup, tough getting the timing right (as the actress said to the Bishop ).
"however, I've been in loads of Octy mini cabs with 200k plus."
Sign of a well-misspent youth
Decisions, decisions.
And, yes, heard similar stories about Octavia mini-cab reliability
Best of luck - just thought I'd put my 2 pennyworth in but you seem to have already done some of the homework
Old 08-06-2007, 09:50   #12
cheezemonkhai's Avatar
I have run cars to 250k+ and what anonymous says is IMHO fairly true.
At about the 80-120k miles mark little things start to go wrong, and then a bit later bigger things. You will end up possibly fixing major components getting past this sort of mileage, eg gearbox might need attention.
If it was me, I would probably sell it on and get a new model. The newer car will have more power as well as supposedly having less issues.
cheezemonkhai is offline
Old 08-06-2007, 12:45   #13
Briskodaholic
Tom_vRS's Avatar
I disagree with reliability concerns. Yes you may well get the odd niggle, but as long as you keep on top of them the car will remain tiptop. And I have a 120k mile Passat thats like new...
I wouldn't hesitate to get a conservative remap either, but tbh I'd leave it at that.
97/R BMW 328i in Boston Green.
Don't miss the new DR COLORCHIPS GROUP BUY!
Tom_vRS is offline
Old 10-06-2007, 19:52   #14
TBH the only thing I've noticed compared to the dealers courtesy cars...
Is my clutch is a bit heavier ....
but then again, I wear size 11 steel toe cap boots most of the time.
Can anyone beat 90k on a set of brake pads btw?
gcr31463 is offline
