39,456 Members 1,489,920 Posts
disc run-out???
This is a discussion on disc run-out??? within the Octavia I forums, part of the Skoda Model Discussion Area category; I am finally getting my new breaks done today and its taken me 2 days to get all the kik ...
Old 14-08-2008, 08:16   #1
claytarget_god's Avatar
Images: 5
disc run-out???
I am finally getting my new breaks done today and its taken me 2 days to get all the kik sorted, the one thing I dont have is a disc run-out gauge.
1. is it necesary on a 3 yr old car?
2. can they be made up easily?
I cant find one that is fairly cheap or even a shop that has them, does anyone know were I might be able to get one from?
cheers
billy
Done: PowerFlex Dogbone Bushes,Forge FMIC,CAI,forge DV, Longlife 200cel Cat 2.5" cat-back,Weitec GT coilovers,Whiteline 22mm ARB and S3 Front Lower Brace,SuperPRO Wishbone/Front ARB Bushes,Remap,LCR Front Splitter, Milotec front grills,EBC grooved/dimpled Discs,Black Diamond Predator Pads,18" Team Dynamic Pro Race 1.2(StarSilver) To Do: TIP,Tinted Windows, Front Bumper: Milotec Side Vents,Milotec Rear Bumper Splitter, RSTuning Custom Remap.
claytarget_god is offline
Old 14-08-2008, 08:44   #2
Octavia Vrs!'s Avatar
Members Car:
Re: disc run-out???
So what discs have you gone for?
Its not really necessary but obviously highlights problems before you put the wheels back on. The disc normally is put in one possition due to the disc retaining screw anyway. What you really need to do is prepare the hub face really well with a stiff wire brush. Doing this should give a true running disc. Any run out will be evident the first time you press the brakes. When I fitted the Compbrake kit I didn't test run out as I too could not get hold of a gauge but with good prep work there was no run out and that was on the 335mm discs which would egagerate any run out compared to the standard 312mm.
There's nothing like seeing feathers going in the opposite direction to the bird!
Octavia Vrs! is offline
Old 14-08-2008, 08:46   #3
Members Car:
Re: disc run-out???
Also Run out should be measured with the wheel bolts fully tightened against the disc. Normally without the wheel on the bolts are too long. It's no use testing run out with just the retaining screw in place as it will be miles out.
Old 14-08-2008, 09:18   #4
Cupra Bush King
Lummox's Avatar
Images: 2
Re: disc run-out???
Sump plug is perfect for this.
www.unit18.co.uk
Lummox is offline
The Following User Says Thank You to Lummox For This Useful Post:
Octavia Vrs! (14-08-2008)
Old 14-08-2008, 11:06   #5
Images: 5
Re: disc run-out???
cheers got the EBC discs
youll see when I put the how to up got loads of pics to fiz thru.
jacking the car is a prob not thou, is it safe to jack the middle of the subframe?
Old 14-08-2008, 12:03   #6
Members Car:
Re: disc run-out???
No, don't jack using the sumframe. Use a good trolley jack on the chassis legs/rails and protect with a piece of wood,
You can see in the botton right of this picture. Good strong location and doesn't destroy the week octy sills. Obviously use axle stands to.
Good luck and looking forward to seeing it all finished
Old 14-08-2008, 12:04   #7
Members Car:
Re: disc run-out???
Very good tip - I've got 2 used ones lying about somewhere
Similar Threads
Disc Changer AndyVRS Fabia I 4 30-01-2008 20:11
Brake Disc help!! moose52c Octavia I 2 10-01-2008 17:40
vrs rear brake disc ridge (in middle of disc) bren Fabia I 7 23-05-2007 18:27
disc to disc copying advice jas328sport The Tech Shed 13 31-12-2006 02:00
brake disc avacab Octavia I 8 22-06-2006 12:43
