This is a discussion on Disconnecting/ disabling rear wiper within the Octavia I forums, part of the Skoda Model Discussion Area category; Yes, you read correctly! Off to the Alps next week with a rear mounted bike rack, there are two straps ...
| Briskodian Join Date: Oct 2007
| Disconnecting/ disabling rear wiper Yes, you read correctly! Off to the Alps next week with a rear mounted bike rack, there are two straps that clip on just above the middle brake light (estate). The straps barely clear the glass so if the rear wiper is operated it will foul on the straps, not good! Any easy, temporary way I can de-activate/remove the rear wiper? I know I'll forget about it, especially when reversing with the main wipers on! |
| Briskodian Join Date: Sep 2006 Location: RH Front seat :)
| Re: Disconnecting/ disabling rear wiper Could you not just remove the arm for the trip? If you lift up the cover at the end there is a nut you undo to take the arm off. ![]() |
| MadridBriskodia Join Date: Jul 2006
| Re: Disconnecting/ disabling rear wiper is there a fuse that just does that?
__________________ who'd have thought it eh? |
| Re: Disconnecting/ disabling rear wiper Fuse 27 (15amps) according to the manual for my 110TDi (2001). That fuse only covers the rear wiper. |
| Not anymore Join Date: Oct 2007 Location: Bournemouth
| Re: Disconnecting/ disabling rear wiper Yes agree just take out the fuse is much more simpler.
__________________ Car now: 56 Octavia MK2 1.9TDi Ambiente-Debadged-Metallic Flamenco Red DMF Reqiured soon ![]() Previous: 06 Octavia Mk1 1.9TDi Classic with + pack-Diamond Silver Sadly missed: 97 Nissan Primera 2.0TDi SLX- Red Paul ![]() I only live for GTA IV |
| Re: Disconnecting/ disabling rear wiper Nice one, cheers. |
| Briskodian Join Date: Feb 2007 Location: Italy, Arquata Scrivia (AL)
| Re: Disconnecting/ disabling rear wiper I also own an Octavia Mk. 1 break and a Thule strap-on bike rack. I prefer removing just the rear blade - hassle free (removing/replacing the fuse may be tricky, the entire arm - out of question). It works fine with my rack as the arm doesn't interfere with the straps. Make sure you put an inch of plastic tube on the arm terminal, just in case you inadvertently activate the rear wiper, otherwise you might permanently scar the glass. |
| Disabling & Enabling Delayed Wiper Operation | VRStu | Technical Guides | 16 | 27-03-2008 20:59 |
| Rear aero wiper and rear sunblind? | UncleRic | Octavia I | 7 | 06-03-2008 00:48 |
| Rear wiper | pinkfloyd | Favorit, Felicia, Fun and Forman | 16 | 28-02-2007 16:57 |
| front screen wiper and rear wiper | janet | Favorit, Felicia, Fun and Forman | 1 | 14-08-2006 19:01 |
| Rear wiper ?? | bryan | Octavia II | 14 | 31-03-2005 21:39 |
