This is a discussion on Drivers window has gone for a sh!t.... within the Octavia I forums, part of the Skoda Model Discussion Area category; Can anyone help..... I need to get the drivers door card off to inspect my electric window mechanism, it has ...
| Silver bullet Join Date: May 2003 Location: Planet Earth......
Members Car: 345bhp Silver Octavia vRS Thanks: 48
| Can anyone help..... I need to get the drivers door card off to inspect my electric window mechanism, it has been making some clunking noises lately and I dare no lower it as I fear it will not go back up!! Has anyone else had this problem? If so what is the best/easiest way of removing the door card? Many thanks Steve ![]() |
Members Car: Octavia 2001, 110TDi Elegance estate Thanks: 0
| Re: Drivers window has gone for a sh!t.... If you have a Haynes manual that covers it reasonably well. From memory: remove tweater remove torex screws from around the side of the trim remove the electric mirror adjuster switch remove a rubber trim around the back of the grab handle remove a number of large screws remove the grab handle assembly pull trim away at bottom of door and unclip power to light ease the trim upwards - it will be a tight fit near to the rubber at the top. then remove the power to the 'locked' flashing LED at the top of the trim. |
| | #3 | |
| Re: Drivers window has gone for a sh!t.... Quote:
