This is a discussion on Fan or water Pump? vrs within the Octavia I forums, part of the Skoda Model Discussion Area category; Was driving to work today and after 10 km, in stop start traffic, the temperature warning light came on. Pulled ...
| Briskodian Join Date: Aug 2007 Location: Bangalore, India
Members Car: Octavia 1 RS 150 Thanks: 2
| Fan or water Pump? vrs Was driving to work today and after 10 km, in stop start traffic, the temperature warning light came on. Pulled over and let the water level come down. Was at a junction to the highway to work. Drove on for another 5 km and there was no probs. Left early to avoid heavy traffic and drove frugally. Car was fine until I reached thick traffic around the corner from my house and he temperature started climbing. Got out and opened the bonnet and found the fans were not turning (by the way my air conditioning stopped working since yesterday). The VAG COM gave no error. Rang up the dealer who says water pump. Car is three years ld but done only 24000 km. So is it the fan only or also the water pump or anything else? |
| ECUless | Re: Fan or water Pump? vrs Are you getting any heat out of the heater?, if so the coolant is circulating so unlikely to be the pump. |
Members Car: Octavia TDi110 Thanks: 65
| Re: Fan or water Pump? vrs It would be most unusual for it to be the waterpump on 24_000km, and the places the car's heating sound wrong anyway. Water pumps usually show up in places you're running 90kph or faster, or over half engine speed for sustained climbs. |
| Re: Fan or water Pump? vrs I checked all fuses and they were okay. wat fooled me is that my heater motor is shot so I could not use that as a point of reference Decided to drive car in stages - i.e. went to one of my offices on the way. Stopped over for 2 hours, no problem, then drove on to dealer. Got stuck in major traffic and saw the needle climb. Switched off and started car to move on as required. Had to pull over near highway access ramp as it was going into the red. Raised bonnet and waited for 10 min. Resumed on the highway at 80 km/h, needle went back to 90 and car was fine. As I got off the highway for the last couple of miles, the needle moved to the red but made it into the dealer. It was quite clear that the fans were out Got another supervisor, not the person I spoke to, and told him to fix the fans and air conditioning. It was a wiring fault. They topped up the gas (they had to charge me for something!). Drove into office and I could hear a long lost hum! |
| Briskodian Join Date: Jan 2004 Location: Ireland
Members Car: Skoda Octavia vRS Thanks: 23
| Re: Fan or water Pump? vrs Get the thermostat checked. I had a problem in my first Octavia RS where the thermostat died causing the waterpump to die. I only had about 20k miles on the clock and just over 1 year old.
__________________ Dear Lord.. The gods have been good to me. For the first time in my life, everything is absolutely perfect just the way it is. So here's the deal: You freeze everything the way it is, and I won't ask for anything more. If that is OK, please give me absolutely no sign. OK, deal. |
| Briskodian Join Date: Jul 2008 Location: Portsmouth
Members Car: Octavia RS Thanks: 1
| Re: Fan or water Pump? vrs Thermostats sometimes jam open - they operate the fan when they close. if your water level is right this is most likely problem. Look at the cheapest option first
__________________ WOW GUYS!!!! look at all my 5 fantastic mods: Green valve caps on each wheel |
| Re: Fan or water Pump? vrs On what planet!!!? The fans are operated by a thermoswitch on the radiator, which means that they can only operate for cooling when the engine is hot and hence the thermostat is open! IME the "normal running temperature" of the engine is such that the thermostat should be open when the engien temperature gauge gets to its "normal hot" temperature. |
| | #8 | |
| Briskoda Staff Join Date: Oct 2005 Location: North Yorkshire
Members Car: AUDI A4 B7 2.0 TDI SE Saloon Thanks: 212
| Re: Fan or water Pump? vrs Quote:
__________________ ![]() ![]() '05 Audi A4 2.0 Tdi SE - no mods until the warrenty expires ... yeah right... interior light pack, 3 spoke mfsw.'00 Audi A4 2.8 Quattro - Gone.... (bleeding money pit )Audi A4 2.6 Avant (Breaking - Check out http://shop.ebay.co.uk/merchant/auroan) | |
| Briskodian Join Date: Mar 2008 Location: Teesside
Members Car: Octy Vrs & Leon Cupra Thanks: 0
| Re: Fan or water Pump? vrs Definatly sounds like a fan problem.It could be the relay box Controller for it. Air con is also linked through this. |
| | #10 |
| Re: Fan or water Pump? vrs On Friday, took the car out and drove for 15 miles around town on some heavy water-logged roads. Some roads were flooded with 5 inches of water but I drove gingerly. Was not using the air conditioner. Return home and pick up the missus for lunch who promptly switches the a/c on and nothing. Stop and see the fans not turning. Since we are 2 km from lunch and 2 km from home - drive home and I spend an hour going over the connections and no luck. Today,start her up to go to the dealer and the fans work. Behaves perfectly and I leave it at the dealer for 5 hours. They can find nothing wrong, so I drive it back and do more driving n wet (no water logged roads). My guess is that is was excess moisture. Now to get some wd40 and spray the connections |
| | #11 |
| Re: Fan or water Pump? vrs ...and it happened again. Again during a high speed run in the rain. Looked at the fuses on top of the battery to find one burnt out and nearly melting the plastic. Replaced the fuse and it started working. Drenched the fuse box in WD40 and hope for the best! |
| | #12 |
| Briskodian Join Date: Aug 2008 Location: Romsey, Hants
Members Car: Skoda Octavia Elegance TDi Thanks: 2
| Re: Fan or water Pump? vrs [quote=KenONeill;1397127]On what planet!!!? The fans are operated by a thermoswitch on the radiator.quote]They certainly used to be, but cooling fans on many modern cars now are switched by a relay which in turn is controlled by the ECM, using the same engine coolant temperature sensor as used for the temperature guage and engine management system. The fans come in when the engine reaches a certain temperature, and in the event of the sensor going open circuit such as the plug falling off the fans come on automatically as a safegaurd. There is one major flaw here though, and that is the thermostat could be stuck closed leading to engine overheating, and the fans would switch on. The radiator would be cold and would have no effect on cooling whatsoever. I would recommend regular thermostat and anti-freeze changes. Every two or three years or so..... |
| | #13 |
| Re: Fan or water Pump? vrs Drove through 400 metres of 7 inch deep water - nothing happened. So, answer is soak the fuse box above the battery with WD40 |
| Octavia vRS water pump. Advice Please. | SCVRS | Octavia I | 9 | 23-01-2008 13:33 |
| Fabia VRS water pump | 53FabiaVRS | Fabia I | 12 | 25-10-2007 07:36 |
| Metal impeller for vRS water pump? | Steevie Wonder | Octavia I | 26 | 02-06-2007 22:58 |
| Vrs water pump | martziniuk | Octavia I | 2 | 27-02-2007 20:20 |
