39,476 Members 1,490,459 Posts
Fault codes - advice
This is a discussion on Fault codes - advice within the Octavia I forums, part of the Skoda Model Discussion Area category; Engine light came on with car, friend had VAG he came round and the system reported this 17705 - Pressure ...
Old 10-08-2007, 10:54   #1
Members Car:
17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
P1297 - 35-00 - -
17545 - Fuel Trim: Bank 1 (Add): System too Rich
P1137 - 35-10 - - - Intermittent
16727 - Camshaft Position Sensor (G40): Signal too High
P0343 - 35-10 - - - Intermittent
16395 - Bank 1: Camshaft A (Intake): Retard Setpoint not Reached (Over-Advanced)
P0011 - 35-10 - - - Intermittent
before i book into garage can somebody advice me on what it is meaning, the car seems to be running fine, fuel as normal, turbo as normal,
thanks
jase
jase555 is offline
Old 10-08-2007, 12:49   #2
KenONeill's Avatar
Members Car: Octavia TDi110
Re: Fault codes - advice
Check the Dump Valve, and all other intake pipework between the turbo and throttle body for leakage before doing anything else.
KenONeill is online now
Old 10-08-2007, 13:42   #3
Members Car:
17705 - More than likely to be the rubbe rhose than joins the metal tube in the driver's side front wheel arch to the turbo inlet. They revised this item to one with a different seal arrangment at the top.
A search on 17705 error codes will reveal the part number.
Goochie is offline
Old 10-08-2007, 13:56   #4
Here's Johnny !
Johnny50's Avatar
Members Car: Fabia vRS
The pipe goochie is talking about is in this thread.
http://www.briskoda.net/forums/octav...re-pipe/51329/
I had the same problem over the past fwe weeks, and i replaced that pipe on wednesday.
Problem gone !
Johnny50 is offline
