Fixed/Variable Servicing
This is a discussion on Fixed/Variable Servicing within the Octavia I forums, part of the Skoda Model Discussion Area category; Our vRS was set to variable servicing but after approx 10k miles/365 days it flagged that it needed a service. ...
Old 29-05-2008, 12:53   #1
Default Fixed/Variable Servicing
From what I have read on Briskoda it looks like the service interval might have been reset from the instrumentation panel.
Is it possible to reset things in such a manner that we are back on variable servicing from the date that the last variable service was performed?
Downhall is offline
Old 29-05-2008, 13:09   #2
skomaz's Avatar
Default Re: Fixed/Variable Servicing
Yep it is - I've had it done - but it needs a visit to a friendly dealer who understand how the regime works and doesn't want to scr*w you for the cost of a service (some will tell you it needs servicing before they can switch it over)
If everything was as reliable as a VW... My Skoda would be at the bottom of the JD Power tables!
Octavia II 2.0 TDi 4x4 Estate and Fabia I 1.9 TDi Estate and Modified Mk1 Mazda MX-5 1.8iS
skomaz is offline
Old 30-05-2008, 21:09   #3
DGW
BRISKODA Staff
DGW's Avatar
When a car is set for variable service intervals, the service interval distance is calculated by evaluating the distance the car travels every 3 seconds for every ignition ON phase with the fuel consumed for the same time and the associated (oil) temperature curve. This gives a measure of engine oil wear caused by thermal load and that value is used to calculate the residual distance to the next service.
If the car is set for a fixed service interval (as appears to be the case in point) then engine oil wear is not being calculated and it follows that it is not possible to reset to a variable service interval without first carrying out a service.
Denis
2007 Fabia vRS - CC, ESP and full leather trim by Seat Surgeons ...48.09 mpg...
DGW is offline
Old 30-05-2008, 21:10   #4
Babs's Avatar
Also, you forget that Hitler used variable servicing....
Babs is offline
Old 30-05-2008, 21:14   #5
U18 Automotive
Lummox's Avatar
Dealers have instructions not to reset a service light unless they have carried out a service.
Unit 18 Automotive Services
Lummox is offline
