This is a discussion on Flood may have fooked my engine!! within the Octavia I forums, part of the Skoda Model Discussion Area category; I took my Octy I through a flood last night on the way home from work. The water was easily ...
| Briskodian Join Date: Oct 2004 Location: Northern Ireland
Members Car: Octy Elegance 110 TDI (2003) Thanks: 0
| Flood may have fooked my engine!! I took my Octy I through a flood last night on the way home from work. The water was easily up to the bottom of the number plate at the front, and the whole of the underside including exhaust was submerged. I kept the revs up and took it easy. The car came through alright, but afterwards when i started it, there was a loud rattle from the engine. It's running fine, but still rattled this morning on starting. The ratlle is loud and sounds like it comes from the bottom of the engine, but goes away pretty much instantly. Anyone know what this could be. Starter??? Thanks in advance JD
__________________ Octy Elegance TDI (110bhp) |
| Briskodian Join Date: May 2005 Location: belfast
Members Car: skoda octavia tdi 130 bhp [170] Thanks: 98
| Re: Flood may have fooked my engine!! hopefully nothin too serious... ![]()
__________________ when i die, bury me upside down so the world can kiss my a.s.s "I spent all my money on cars, booze and women - the rest I just wasted" - George Best. I was so poor growing up...If I wasn't born a boy..I'd have nothing to play with. -Rodney Dangerfield |
| Re: Flood may have fooked my engine!! Fingers crossed. I checked the air filter and airbox, and no sign of any water ingress. When i opened the bonnet i discovered that half way up my radiator is covered in grass ![]() JD
| Briskodian | Re: Flood may have fooked my engine!! Might just be a bit of water got in near the clutch. Give it a good spirited drive when it's safe to do so and up to temperature.
Members Car: Octavia TDi110 Thanks: 63
| Re: Flood may have fooked my engine!! - If you'd hydrauliced the motor, you'd still be in the flood! |
| Briskodian Join Date: Nov 2003 Location: Hampshire
Members Car: Superb TDI (Octy vRS in storage) Thanks: 11
| Re: Flood may have fooked my engine!! Would also suggest that you check that the force of the water hasn't bent any plastic bits or the like which now rattle against something on start up. Would sound like you haven't got too much to worry about.
__________________ Lee Want to be carbon-neutral while driving? Hold your breath! |
Members Car: Skoda Fabia Mongrel Images: 5 Thanks: 75
| Re: Flood may have fooked my engine!! Aye! Hydraulicing = stop dead and end of story. Sounds like you just have water somewhere it's not used to having water and a good run or simply running it as normal until it dries out will help. With the low air intakes on those cars I'd be very wary about going through any flood. Is there a snorkel mod for the octy, a la landrover?
__________________ Jason - Only a Skoda. Custom Fabia Bonnet Lifter Kits - £45! Click Me. Cheesy bonnet lifter video to "raise me up" http://www.youtube.com/watch?v=hMnGECEi5Oc See the mongrel's 260bhp Dyno Video! |
| Re: Flood may have fooked my engine!! Actually, it is possible that the air filter got soaked, which will stop the car running properly. Still, the fix for that is entirely straight-forward. |
| | #9 | |
| Briskodian Join Date: Feb 2007 Location: Devon
Members Car: Mk1 black octavia vrs Thanks: 3
| Re: Flood may have fooked my engine!! Quote:
__________________ Black octy mk1 VRS... with some mods. | |
| Flood damage :-( | Yes_Dear | Octavia I | 9 | 07-08-2007 14:48 |
| Flood | Fabia1.4 | Fabia I | 16 | 26-06-2007 10:49 |
| Will it bash out? Or is it fooked? | faboka vrs | Maintenance & Performance | 23 | 06-06-2007 15:52 |
| fooked tyre lucky really | VikkiVRS | Fabia I | 16 | 18-04-2005 11:24 |
