This is a discussion on FMIC performance gain....... within the Octavia I forums, part of the Skoda Model Discussion Area category; I have just fitted a Jabba FMIC to the Octy (Exhaust, DV, filter, Std Map) and the car is a ...
| Briskodian Join Date: Jun 2007 Location: Derby / Exeter
| I have just fitted a Jabba FMIC to the Octy (Exhaust, DV, filter, Std Map) and the car is a completely different animal. The turbo lag has increased, which is expected but the boost pressure has increased from 0.8 bar to 1.1bar+. I have read by lots of people on here that the FMIC should actually reduce power but it seems to have done the opposite on my car. The car seems to be much more powerful on boost and a lot quicker. Does anyone have any experience of this? Should I be concerned? Could the old SMIC have been blocked / damaged? Cheers
__________________ Current Mods - Milltek Exhaust, Forge Recirculating DV, Pipercross panel filter, Fast rd Pads and Discs, Coilover kit, Front mounted intercooler, 18" Alloys, Forge TIP, a few stickers and plenty of ICE Planned Mods - Highflow Cat, Custom Re-map |
| Briskodian Join Date: Aug 2006 Location: Watford
| I have the pro alloy on mine also but I'm running a custom IP map which is just over 1 bar so I'm not sure who your getting more boost on a standard map ![]() Your not going to get much if any gains for a FMIC but it will keep the intake temps down and come the summer you will have lees heat soak
__________________ Octavia VRS A standard looking car with a twist of Impossible Performance ![]() Herts South Mimms Meet 30.10.2008 |
| An FMIC should not give more power unless it actually reduces intake temperature, and even then only if you increase fuelling to exploit the fact.I am pleased to have a practical confirmation of my argument that the extra volume can cause lag though. |
| Here's Johnny ! Join Date: Nov 2004 Location: Edinburgh
| Extra lag is definately to be expected, but never seen one give more boost. I fitted an HKS fmic to my Impreza, boost came in around 4-500rpm later then before fitting, and boost dropped around 0.2 bar overall. |
| It definately is giving more boost! Either that or the boost gauge is not reading right!! Could it be related to the DV adjustment? I am seeing just under 1.1bar boost on an un mapped car - is this normal? If so could it be that the old cooler was blocked?
| Maybe you have cured a boost leak by changing the IC and assossciated pipework ![]()
__________________ ![]() |
| | #7 | |
| Quote:
I know revo and jabba can give about 1.3bar but not sure how your getting 1.1 unmapped? Have you had the car from new? Are you sure it's not been mapped?
__________________ Octavia VRS A standard looking car with a twist of Impossible Performance ![]() Herts South Mimms Meet 30.10.2008 | |
| Need more power Join Date: Feb 2007 Location: Driffield, Good old yorkshire
| 1.1 bar is high for a standard car it should be around 0.8.
__________________ Regards Martin Turbo back blueflame exhaust |
| Car used to boost to 0.8 bar - fitted FMIC and it now boosts to 1.1 and settles to 1 bar. Had the car for a year and bought from HSBC bank manager! pretty sure its not mapped!
| | #10 |
| Ah, if the DV has been adjusted, that could be giving you more boost before it dumps. If a FMIC makes a difference to the charge temperature, you'll get T \/ , which will lead to P\/ . Supporting reference:- Thermodynamics - Wikipedia, the free encyclopedia |
| | #11 |
| Ken, Are you just a living, breathing book of knowledge ??? ![]() Certainly know a lot about certain subjects. Obviously stuck in at the old Physics ![]() |
| | #12 | |
| Quote:
__________________ Regards Martin Turbo back blueflame exhaust Last edited by martziniuk; 22-05-2008 at 10:06. | |
| | #13 |
| It feels like yes, or maybe I'm just bright enough to know who to ask? ![]() |
| | #14 |
| I understood that a DV was an alternative to a wastegate, in which case surely its function is to restrict maximum boost? |
| | #15 |
| thats the n75 dv lets off when there is to much pressure, say when you let your foot off. It prevents the turbo fins bending etc. Afaik
