This is a discussion on Front anti roll bar.... within the Octavia I forums, part of the Skoda Model Discussion Area category; My front arb bushes are shot and I need to replace them ASAP, but do I upgrade the arb at ...
| Silver bullet Join Date: May 2003 Location: Planet Earth......
| My front arb bushes are shot and I need to replace them ASAP, but do I upgrade the arb at the same time I have powerflex poly bushes all round...(apart from the front arb!! ) have an Eibach rear arb and am looking to fit Weitec adjustable coilovers pretty soon, is a 21mm or 23mm arb a good option with this combination? Or do I stick with the standard 19mm bar?Any help, and prices etc. will be much appreciated Cheers in advance ![]()
__________________ The silver bullet Jabbasport's; IHI Stage 3 vf34, ceramic lined manifold, F.M.I.C, boost controller, Snowperformance methanol injection, ABD Racing ceramic inlet manifold & CAI, K&N monster filter, 02M 6 speed TDi gearbox, Peloquin a.t.b, Sachs SMF & sports clutch, Forge quickshift, APR R1, Blueflame 3" d/p, 100 cell cat, Milltek 2 ¾" system, Samco; i/c, turbo & boost hoses, Bosch 440cc injectors, 3" M.A.F, SuperPro bushes all round + engine mounts, Weitec coilovers, Eibach rear arb, AP Racing 6 pots & 335mm floaters, S3 top & bottom braces, Nomad; turbo, oil pressure, oil temperature & battery gauges.![]() |
| BRISKODA Staff Join Date: Oct 2002 Location: darkest Hampshire
| Re: Front anti roll bar.... Polybushes will stiffen it up nicely. However I would warn of uprating the front arb....if you've uprated the rear arb uprating the front will more than likely negate this and you'll get understeer again. Also if you intend to get adjustable coil overs this again will reduce the need to uprate the front arb. I had the adjustable rear arb and KW V3.....virtually no understeer in dry.
__________________ Adrian. |
| | #3 | |
| SMOGUS MAXIMUS Join Date: Jan 2005 Location: Essex
| Re: Front anti roll bar.... Quote:
No under or over steer. | |
| Cheers for the advice guys
| Briskodian Join Date: Jan 2007
| Re: Front anti roll bar.... i went for the standard ones from skoda made a big difference in the sound in the car...no knocking now ![]()
__________________ SILVER X5 4.4 SPORT 286BHP. MY OLD OCT VRS 32MPG X5 22 MPG.![]() SOLD JAP INTEGRA TYPE R, DC2, NOW GOT A 4X4 PAJERO...... |
