This is a discussion on Front and Rear Brakes within the Octavia I forums, part of the Skoda Model Discussion Area category; too many parts to find correct fittings , has any one the correct part numbers or size ( 280/288/312 for ...
| Briskodian Join Date: Jan 2005 Location: kent
Members Car: OctaviaElegance 130 TDI Thanks: 26
| Front and Rear Brakes too many parts to find correct fittings , has any one the correct part numbers or size ( 280/288/312 for Front and Rear brake sets on the Octy TDI 130 bhp .Also do i need the wear indicator pads for the front . Thanks |
Members Car: Fabia 2.0/Felicia Thanks: 48
| Re: Front and Rear Brakes mk1 or mk2 octy?? they wont be 280mm that's for sure, vw group havn't used 280mm discs for ages Last edited by TeflonTom; 29-01-2007 at 00:48. |
| Re: Front and Rear Brakes Sorry Mk 1 , as its the 130 bhp 6 speed ( why buy a mk 2 at 140 ) well i will when i have enough dosh for the VRS . ![]() |
| Re: Front and Rear Brakes more likely to be 256mm or 288mm there will be a code somewhere either 1LQ or 1LS on the chassis label |
| Briskodian Join Date: Jul 2006 Location: Sussex
Members Car: 2003 MkI L&K PD130 OCTAVIA Thanks: 0
| Re: Front and Rear Brakes GSF parts for mine (2003/53 130PD L&K) were 60190 Front Disc @ £ 23.50+vat each (288mm) 64332 Front pad set @ £ 37.50+vat (wear ind on pasngr side only) |
| Re: Front and Rear Brakes Thanks for the input . looks as if the fronts are 288 , can i assume that rear are 256 as these seem to be the ones mainly advertised for vw models .. |
| Re: Front and Rear Brakes I've never bought any, but according to Haynes all the diesel rears are 232mm x 9mm. GSF have an enquiry facility on their website, if you put in your car's details they will get back to you with (their) appropriate part numbers. |
| Re: Front and Rear Brakes |
| | #10 |
| Re: Front and Rear Brakes dont believe everythin the haynes manual tell you tho..... the fabia one is full of mistakes |
