This is a discussion on fuel consumption within the Octavia I forums, part of the Skoda Model Discussion Area category; This is my first post on this site, so i hope someone can help. My Octavia VRS is a 52 ...
| Briskodian Join Date: Jun 2007 Location: Brighton
Members Car: Octavia VRS black magic Thanks: 4
| fuel consumption This is my first post on this site, so i hope someone can help. My Octavia VRS is a 52 reg which i have had from new. All was well until i had an engine re map at MRC tuning at Banbury.(up to 222bhp) It started to feel like it was misfiring when i took my foot off the accelerator, and it kept forcing my ignition coils upwards and off the plugs. this stopped happening when i replaced the plugs and coils but the hesitancy remains. on hard acceleration it is fine but driving sensibly causes the problem to surface. My fuel consumption has recently fallen and on my 40 mile commute to work i average about 25/26mpg, less if i have fun.Also sometimes when i start it up it will cut out again sometimes twice before starting normally. Any body know how to solve these problems and improve fuel consumption? |
| Briskodian Join Date: Jul 2007 Location: Kent
Members Car: 1U55R4 Thanks: 22
| Re: fuel consumption mixture too rich? timing out? are you using 95 RON as opposed to 98 RON? Rolling road by a professional! |
| The Following User Says Thank You to G-slave For This Useful Post: | Scon (18-07-2007) |
| Why So Serious Join Date: Jan 2006 Location: "What" ...What ain't no god damn country
Members Car: a car Thanks: 272
| Re: fuel consumption Do you have access to vag com Can you take it back to the tuners 222 bhp seems a bit high it may be that they have over done it abit I am just guessing here, someone more knowlegable should be along to help at some point |
| The Following User Says Thank You to fatty5000 For This Useful Post: | Scon (18-07-2007) |
Members Car: Octavia TDi110 Thanks: 65
| Re: fuel consumption Try disconnecting the MAF. If the engine doesn't run worse, we have a winner. Do the plugs look sooty when you take them out? If so, the engine's running rich, which suggests either the lambda's FUBAR or the map's over-fuelling. |
| The Following User Says Thank You to KenONeill For This Useful Post: | Scon (18-07-2007) |
| Briskodian Join Date: Jan 2007 Location: Oxfordshire
Members Car: Unmodified Octavia vRS Thanks: 1
| Re: fuel consumption I'm assuming that the car was in fine fettle before the remap. If so take it back to MRC. I don't believe you should get poor running. Fuel consumption is likely to suffer if you are using the extra power but you can put up with that. It does sound a bit excessive though. I'm sure MRC would welcome the opportunity to prove their remap is as good as the competition in the area...and there is quite a lot of that!
__________________ If I ever feel like getting fit, I lay down and wait for the feeling to pass over. Sud Sprint preserved in fibreglass! |
| The Following User Says Thank You to Morley For This Useful Post: | Scon (18-07-2007) |
| Re: fuel consumption Ken Whats the MAF, or the Lambda fubar? |
| Re: fuel consumption Your MAF is the Metered Air Flow unit which sits just after the air box in your engine bay located here Maf ring.JPG The lamada sensor sits in your exhaust and fubard means its f****d as in donald ducked HTH ![]() Last edited by fatty5000; 26-07-2007 at 13:55. |
