This is a discussion on Gauges for a vRS within the Octavia I forums, part of the Skoda Model Discussion Area category; Hi, Does anyone know where I can pick up an OEM looking set of gauges that would fit in the ...
| Briskodian | Gauges for a vRS Hi, Does anyone know where I can pick up an OEM looking set of gauges that would fit in the space below the sterio? Ideally I would like it to look factory fitted (i.e. the same theme as the dash dials) and show AFR / Boost etc. Also what it generally accepted as the best place to get a re-map done to appox 225 bhp? I would consider a rolling road remap if this is the best idea however my car is standard so maybe an off the shelf map will do. Many thanks, Anthony |
| Briskodian Join Date: Jul 2006 Location: Cleveland
Members Car: Passat Sport TDi Thanks: 206
| Re: Gauges for a vRS I think the most factory looking gauges are the VDO ones, they don't match the standard gauges but they look stock next to the rest of the dash. I'm not sure where to get them but if you google it you should find some suppliers. |
