This is a discussion on Gear changing within the Octavia I forums, part of the Skoda Model Discussion Area category; 02 octavia 19tdi 130k carnt get 3rd or 4th gear correctly sometimes in will go in sometimes it will not ...
| Briskodian | Gear changing 02 octavia 19tdi 130k carnt get 3rd or 4th gear correctly sometimes in will go in sometimes it will not any idears anyone |
| Briskodian Join Date: May 2008
Members Car: Octavia Estate 1.9TDI Elegence Thanks: 5
| Re: Gear changing That might be a simple quick fix at your local service centre. I had something similar with my Golf on about the same mileage. First gear was getting very hard to get in to. They took it in for an estimate and fixed it on the spot by adjusting the linkage. |
| Briskodian Join Date: Jun 2005 Location: yorkshire
Members Car: 2005 Octy II 4x4 TDi Estate Thanks: 0
| Re: Gear changing Hope you don't end up with the same problems mines having - only briefly had my car back during the last 7/8 weeks due to gear selection/de-selection problems. Dealer has been told to do everything by Skoda and so far failed to solve the problems, Skoda still won't authorize a new box but can see it ending up with getting one fitted! |
| Proud new Dad Join Date: Feb 2007 Location: Carlisle, Cumbria
Members Car: Octavia vRS TDi Thanks: 165
| Re: Gear changing I would think that an adjustment of the gear linkages may be all that is required. Even though my local dealer insisted it was the clutch when my fabia did similar.
__________________ Running on the fuel of Satan.... |
| Briskodian | Re: Gear changing If it's just a pair of gears opposite eachother (1&2, 3&4) it's the corresponding selecting lever in the linkage, an easy adjustment/replacement. Just don't grind it too much into gear until you get it sorted.
__________________ Milk Inc's newest #1 fan |
Members Car: Octavia TDi110 Thanks: 65
| Re: Gear changing Start with checking the linkage adjustment. If it's not that, check the "console bush" bolts are stupidly tight, and then that the "dogbone" doesn't need replacing. |
| Changing gear? | gmaster | Octavia I | 6 | 05-10-2007 11:37 |
| Gear Changing in vRS | rainbow-walker | Fabia I | 17 | 25-12-2006 10:43 |
| Changing handbrake and gear **** | andy ellis | Fabia I | 2 | 02-11-2006 16:59 |
| Changing Gear without the Clutch | H Bomb | General Car Chat | 22 | 10-08-2006 22:02 |
| Gear changing anomoly | devonutopia | Maintenance & Performance | 9 | 27-11-2003 08:50 |
