39,456 Members 1,489,922 Posts
Gear Lever Rattle/Noise
This is a discussion on Gear Lever Rattle/Noise within the Octavia I forums, part of the Skoda Model Discussion Area category; I'm getting a rattle/noise from the gear lever on my 2001 110TDI. I've had a quick look in the forums ...
Old 24-05-2006, 12:37   #1
yaktrebor's Avatar
Location: Bakewell, Derbyshire, where the puddings come from. (That's tarts to foreigners!)
Members Car:
I've had a quick look in the forums and only found information on VRS gear levers.
Anybody know if this is a common fault and if so, is there a cure?
I guess its something to do with the linkage?
'No more beer!' (unless it's GF)
yaktrebor is offline
Old 24-05-2006, 12:47   #2
mbames's Avatar
Re: Gear Lever Rattle/Noise
I find the same on my 2001 110TDi as well. It happens in 3rd and sometimes 5th. Gently resting my fingers on the top of the gear lever (I resist the temptation to say kn*b!) cures it.
There appears to be a little bit of play in the top of it, but I have not investigated pulling it off yet. I did wonder if I might pull it off and be able to pack it out with some PTFE tape...
mbames is offline
Old 24-05-2006, 12:57   #3
yaktrebor's Avatar
Members Car:
The noise from mine seems to be coming from under the car somewhere.
Old 24-05-2006, 14:24   #4
cheezemonkhai's Avatar
Members Car:
If it is the same as I had in my 2003 TDI it's the little know at the end of the handbrake. Hold it and see if the noise goes.
I got it changed under warrenty, but it was a whole gear leaver job
cheezemonkhai is offline
Old 24-05-2006, 15:16   #5
yaktrebor's Avatar
Members Car:
The noise is the handbrake?
But is fixed with a new gear lever?
Is this what you are saying?
Old 24-05-2006, 15:34   #6
robmawer's Avatar
Members Car: Octavia 1.6 Ambiente
If you open and remove the ashtray, you should be able to grip the front of the plastic gear lever surround and pull if gently but forcefully upwards to unclip it.
Once you lift that and the gaitor up, you'll be able to see how the **** is attached to the shaft.
Mine was secured with a jubilee clip, you might find yours is too and it just needs a tighten...
Rob.
robmawer is offline
Old 24-05-2006, 16:16   #7
mbames's Avatar
cool... I might have alook over the weekend!
mbames is offline
