This is a discussion on Gearbox Drag? within the Octavia I forums, part of the Skoda Model Discussion Area category; was chatting in another post about my RR figures... and again the subject of my drag came up? i have ...
| Briskodian Join Date: Nov 2006 Location: Bristol
Members Car: Octavia VRS Thanks: 103
| Gearbox Drag? was chatting in another post about my RR figures... and again the subject of my drag came up? i have wondered about this b4 as it seems oddly high? does anyone have any idea how to tackle and solve this prob? ive been told the drag should be around 20 25bhp? so i have a few loose horses i need to tame? i tend to have no luck with this tunning lark damit...![]() help!
__________________ |
| Briskodian | Re: Gearbox Drag? Get a plane |
| Re: Gearbox Drag?
| Why So Serious Join Date: Jan 2006 Location: "What" ...What ain't no god damn country
Members Car: a car Thanks: 272
| Re: Gearbox Drag? Short of removing your gearbox, I'm at loss as to what you can do. It maybe the rolling road talking nonsense or it could be those wheels. I am no expert on this though so you can probably write these statements off as utter borrax. |
| The Following User Says Thank You to fatty5000 For This Useful Post: | Lloyd55vrs (26-06-2008) |
| Re: Gearbox Drag? the rolling road was with the 18s i had? on the actual road against my mates standard vrs and my brothers there is no doubt, breakie dinner and tea ![]() the rolling road was at TSR maybe worth a 2nd RR somewhere just to see how it matches up? very annoying ![]()
| Briskodian | Re: Gearbox Drag? The easiest way of getting more go is reduce weight. Have you considered this. Its cheap and easy to get started. |
| | #7 | |
| rodeo monkey Join Date: Jan 2005 Location: blah, blah, f*****g blah!
Members Car: an old focus Thanks: 13
| Re: Gearbox Drag? your big heavy wheels probably aren't helping ![]()
__________________ Note: This statement was most likely made with a usual dry sense of humor. It was in no way made to offend anyone who may be easily offended. If you find yourself offended by such a statement, you needed more hugs as a child, or more beatings. Whichever you didn't get enough of, you need more of. Probably beatings. Quote:
| Re: Gearbox Drag? would the 18" tsw have casued that much extra drag n loss tho? if its usually 20ish its 30 odd horse running around lol i could see the 20s causing abit but 25 30 bhp seems alot?
| Briskodian Join Date: Dec 2004 Location: Hawkinge Kent
Members Car: Superb Comfort 1.9 TDi 130 Thanks: 16
| Re: Gearbox Drag? How was the engine power measured, did the RR plug into the ECU? (I have not been on a RR for over 15 years, and that was with a non ECU motor). The way they USED to work was they would give you the power @ the wheels and then an estimated flywheel figure (unless the engine was dyno run, it could only be an estimate) I agree that your big (= heavy) wheels will be loosing you power. |
| | #10 | |
| Re: Gearbox Drag? Quote:
i dont think anything was plugged in
__________________ | |
| | #11 |
| Need more power Join Date: Feb 2007 Location: Driffield, Good old yorkshire
Members Car: octavia VRS Thanks: 54
| Re: Gearbox Drag? I get 35bhp drag if its any help. Would a Seized brake caliper cause the extra drag?
__________________ Regards Martin Turbo back blueflame exhaust |
| | #12 |
| Re: Gearbox Drag? That was the case when i used to use a RR the figures were purely from the rollers themselves. If nothing is plugged into the ECU then the 225BHP figure is only an guesstimate. The true figure (and IMO the only one that matters) is the 170 BHP @ the wheels. It's a bit annoying when manufactures only quote the flywheel figures of an engine, because unless you are just buying just an engine the figures are pretty worthless. The BHP @ the wheels is what matters. All you can do to reduce the losses are by fitting straight cut gears (noisy and not as strong) that do not loose as much power through the transmission and lighter wheels. |
| | #13 |
| Re: Gearbox Drag? Yes, anything that makes moving the car forward harder will hamper the figures. Although a sticking caliper is pretty easy to spot, as that wheel will get covered in brake dust much quicker than the opposite one. |
| | #14 |
| Re: Gearbox Drag? I've just replaced my front tyres. I had the choice of the cheaper 225's but opted for 205's due to having better straight line speed and giving less drag.
| | #15 | ||
) when on the dyno ![]()
| The Following User Says Thank You to andypandypoos For This Useful Post: | Lloyd55vrs (26-06-2008) |
| | #16 | |
Members Car: Octavia TDi110 Thanks: 65
| | #17 |
| Re: Gearbox Drag? Thats what i was always led to believe, until i was proved wrong by Quaife. |
| | #18 |
| Briskodian Join Date: Jul 2007 Location: Oxfordshire
Members Car: Octavia Vrs Thanks: 37
| Re: Gearbox Drag? have you thoguth about trying another set of rollers? as maybe that the resistance figure was bumped up to give higher engine power?
__________________ Must Go Faster |
| | #19 |
| Re: Gearbox Drag? |
| | #20 | |
if 35 has been seen as a drag could it maybe be a 20bhp error lol i will also keep an eye on brake dust on the wheels? the car doesnt get massive amounts of use .... its only just creeping upto 10k
| | #21 | ||
) but they put less stress on things like bearings and casings and make for a potentially stronger gearbox?
| | #22 |
| Re: Gearbox Drag? I was told that the other way round; IE straight-cut are stronger despite an individual tooth of given cross-section and width being weaker, because the actual contact patch is the full length of the tooth (easy to believe if you've ever seen helical-cut gears in mesh: It's obvious that they don't make contact over their full length at any given time). |
| | #23 | |
| Re: Gearbox Drag? I could well be mis-remembering, but there was something about helical gears having two teeth (partly) engaged at the same time which meant less stress and less wear on each - the teeth themsleves aren't any stronger, but in practise the gears are?
| | #24 | |
Gizmo, can you remember Quaiffe's argument in more detail? | |
| | #25 |
| Briskodian Join Date: Aug 2006 Location: East Lothian
Members Car: Octavia vrs Images: 2 Thanks: 17
| Re: Gearbox Drag? According to various sources, the way to guesstimate engine power is to add 10 to wheel bhp then divide by 0.9 for a F.W.D. car the result is Approx engine power. In your case 170@wheels would work out at 200BHP @ flywheel so only 30 Bhp loss. Which seems reasonable.
__________________ Diamond silver octavia vRS,xenons,Jetex downpipe with sports cat,Jetex cat back system,Green panel filter,Forge i pro remap,Forge 007 dv,Milotec bumper grills,TT arch vent mod. |
