39,456 Members 1,489,925 Posts
Gearbox oilchange help
This is a discussion on Gearbox oilchange help within the Octavia I forums, part of the Skoda Model Discussion Area category; I'm after changing my gearbox oil but having never done it I need help to locate the filler plug and ...
Old 12-05-2008, 19:01   #1
Lex Dysia's Avatar
Members Car: Skoda Octavia VRS 2002
I'm after changing my gearbox oil but having never done it I need help to locate the filler plug and the drain plug. Any help greatly appreciated
Upper & Lower S3 Strut braces-Forge FMDV006 DV-PiperX panel filter-Whiteline adjustable rear arb-Superpro Dogbone, Control arm & Front ARB bushes-LCR Splitter-Milotec Grilles-Golf MK4 Aero wipers-KVW100-Cruise Control-Parking Sensors-18" RS8 Alloys-N75H-Revo Stage 1-TO DO: Turbo back exhaust-Koni FSD and H&R springs (5 Days to go)-Seat & Door Card Leather retrim and a respray.
http://briskoda.net/images/vbseo_skin_1.0/logo.gif
Lex Dysia is offline
Old 12-05-2008, 19:36   #2
DGW
BRISKODA Staff
DGW's Avatar
Re: Gearbox oilchange help
According to Haynes, the transmission filler/level plug is situated on the front of the transmission casing. To get at it you will need to first remove the engine undershields. The job is best done on a ramp but failing that jack the vehicle up and support it front and rear on axle stands so that it is level. You will need 1.9 litres of Skoda (or equivalent) G50 SAE 75W/90 synthetic gear oil. (Autodata CD2 says 2 litres).
Haynes doesn't mention a drain plug...
Denis
DGW is offline
Old 12-05-2008, 19:40   #3
Cupra Bush King
Lummox's Avatar
Images: 2
To do it 'properly' you need to remove the filler plug and the diff drain plug. The take out one of the selector pins from the casing and drain the box out, this gets the oil out of the casing not just the diff. then replace the o ring on it , refit drrain bung and refill. Takes around 2 litres.
Go some propper oil and the correct filling tool if you want to borrow it, does make life a lot easier.
www.unit18.co.uk
Lummox is offline
Old 12-05-2008, 19:51   #4
Lex Dysia's Avatar
Sounds a bit complicated lummox Would I get away with sucking the old oil out from the filler and refilling it, not ideal I know but I figure with fresh oil it has to be better for the box
BTW I was going to use millers trx synth 75w90 is this ok?
Old 12-05-2008, 20:01   #5
Cupra Bush King
Lummox's Avatar
Images: 2
No you cant suck it out through the filler it wont get anything out. Its not complicated just needs to be dont right. Not sure on the trx synth tbh, synthetic gearbox oils seem to cause nothing but balll ache in VAG vehicles in my experiance. I have plenty of the propper oil going spare. Can give you a hand chaging it if needs be. Could even do a little how to maybe.
www.unit18.co.uk
Lummox is offline
The Following User Says Thank You to Lummox For This Useful Post:
Lex Dysia (12-05-2008)
Old 12-05-2008, 21:30   #6
To Carry out a 20k service all that is required is to check the oil level.
Make sure the car is level, remove the onside wheel and the plug can be removed with a 24mm alen key (this cost me 7 quid) The oil level should be level with the underside of this plug.
Hope this helps?
slackbladder is offline
Old 12-05-2008, 21:31   #7
Cupra Bush King
Lummox's Avatar
Images: 2
Pretty sure the gearbox oil level check is on the major service (40K).
www.unit18.co.uk
Lummox is offline
Old 12-05-2008, 22:13   #8
Lex Dysia's Avatar
Thanks Lummox may take you up on that, Don't really want to start something that I may not be able to finish. Why cant it be simple like engine oil change . Car has covered nearly 100k so reckoning it could only do it good, havent had any gearbox probs I'm just a believer in regular fresh fluid changes. Will pm you and we can arrange something hopefully
Old 13-05-2008, 03:37   #9
cheezemonkhai's Avatar
Members Car:
I used the TRX fully synth gear oil in my TDI 110 and it worked a treat, but if ross has the VAG stuff going for a good price.
cheezemonkhai is offline
Similar Threads
gearbox jvaleiron Octavia I 2 12-05-2008 12:26
Fabia vRS gearbox - 75w90 gearbox oil? devonutopia Fabia I 6 15-12-2007 13:23
gearbox 999mdh Octavia II 1 26-11-2006 16:59
Help! need a new gearbox now!!!!! Mr Peas Octavia I 9 04-04-2006 16:48
