This is a discussion on Gearbox trouble within the Octavia I forums, part of the Skoda Model Discussion Area category; Had myoccy for 3 1/2 years now nothing has gone wrong in that time (except where i broke it) this ...
| Briskodian Join Date: Dec 2002 Location: Houghton Regis
Members Car: elegance estate TDi Thanks: 0
| Gearbox trouble Had myoccy for 3 1/2 years now nothing has gone wrong in that time (except where i broke it) this week 2 problems, the first (brake light switch) i have fixed. the second is when stationary putting car int 1st 2nd or reverse is really hard it sort of double clunks. if moving even rolling at snails pace it is a lot easier, 3rd and 4th when stationary are also harder but no where near as bad I have read all the forums and seem to have come to the conclusion that i need a gearbox oil change at least. question is can i do this myself? where are the filler/emptyier plug's what is the best oil to use. i am fairly mechanically minded are there any gotchas i should watch for? also anyone have to hand the quantiy of oil i should put in ?I know it could be the gearbox gone or the clutch playing silly Bug****s but it cant hurt to try the oil first. Car is a 2001 occy TDi 110BHP with 98,000Miles ![]() Last edited by g7pkf; 07-04-2005 at 21:54. |
Members Car: 4x4 turbo estate Thanks: 17
| sounds like the clutch might be on the way out not bad for age and milage thoughmine went at about this age but a bearing went in the gearbox soon after too, don't think the clutch helped this problem
Members Car: Octavia 1.8T 4X4 Estate & Fabia vRS Thanks: 51
| Autodata CD-2 lists the gearbox oil as being 75W/90 synthetic - 2 litres.
| Have now had a "mechanic" check it out Say's it's clutch but i am finding quotes are coming in at about £350 some are £500 and a dealer said if it was some funny intergrated into the flywheel one it would be £900+ is this about right seems a bit excessive? Last edited by g7pkf; 08-04-2005 at 11:36. |
| ETKA lists a flywheel with clutch for the ASV engine as being circa £719.03. There must be other sources of that, eg www.Skospares.com or Euro Car Parts. Perhaps members can suggest other places to try.
| ouch Guess what engine i have!! my book says it's a 81KW ASV ![]() |
| | #7 | |
| booked it in Quote:
differance being they know what they are doing and look after my car while they have it. also getting gearbox oil changed while they are working on it seems a good idea considering the milage and after reading the failures at about 100K thought it would be a good idea. cheers fro everyone's advice G7PKF | |
| When did Fabia vRS change to new gearbox? | tfboy | Fabia I | 23 | 16-05-2005 21:18 |
| Gearbox Problems | maxcars1 | Fabia I | 7 | 04-12-2004 13:21 |
| Gearbox going to drop out?? | vRS_Si | Maintenance & Performance | 6 | 21-10-2004 10:19 |
| Audible Noise from Gearbox - Octy vRS | ventmore | Maintenance & Performance | 0 | 29-08-2004 16:33 |
