39,456 Members 1,489,922 Posts
Grinding selecting reverse
This is a discussion on Grinding selecting reverse within the Octavia I forums, part of the Skoda Model Discussion Area category; I have an issue that when i select reverse it often grinds, which i am guessing it shouldn't do. Sometimes ...
Old 17-06-2008, 10:08   #1
mrmo's Avatar
Members Car: Octavia GLX
I have an issue that when i select reverse it often grinds, which i am guessing it shouldn't do. Sometimes i find that the car is reluctant to let me select other gears, mainly first! and typically on a **** off steep hill!Looking through threads it seems it could be the clutch or the selector? anything else? The clutch doesn't seem to slip, i live on a slight hill so i assume i would find out as it would have issues pulling away in the morning. How woould i know which is at fault and what would be involved in fixing either issue?The car is at 129k and counting.
mrmo is offline
Old 17-06-2008, 10:26   #2
VRSPhil's Avatar
Members Car: Passat Sport TDi
Re: Grinding selecting reverse
I had problems selecting first and reverse when the gear linkage needed adjusting. This is a simple process, but I can't remember it well enough to give a reliable description. It's covered in the Haynes manual, or someone else may be able to describe it.
It's worth a go IMHO, as it takes 10 minutes max and costs nothing.
I also find that they grind into reverse if you try and select the gear too quickly after depressing the clutch. I read somewhere that waiting a few seconds between depressing the clutch and then selecting the gear will prevent the grind. Obviously I don't know if you have a fault, but again it may be worth trying if you haven't already.
*EDIT - I was never overly impressed with the action of my gearbox when I bought the car. I found that changing the gear oil made a big difference.
'54 Passat PD130 Sport... 55mpg
Octavia vRS WRC - Gone but not forgotten!
VRSPhil is offline
Old 17-06-2008, 21:22   #3
mrmo's Avatar
thanks, had a look at the haynes guide and did as it said, seems better standing still. Will see how it is tomorrow.
But, not quite perfect, still a little noise getting reverse. Is there anything to ensure that the gear stick stays perfectly central. It seems that it moves a little when i am sorting the cables out.
mrmo is offline
Old 18-06-2008, 07:22   #4
Hardcore
Basil's Avatar
Members Car: Fabia vRS
look halfway down this page: Sigma 6 Install Manual
Gives the adjustment procedure. Really easy and I need to do mine, same prob.
The crappy plastic/rubber bushes on the cable wear/loosen.
HTH
BTW What tranny oil did you switch to mate? Or was it a case of replacing the OEM stuff?
Cheers
Bas
Fab vRS - Black Magic - PD160 intake - Forge FMIC - colour coded front grille -SLC Splitter - K&N Airfilter -SEAT Strutbrace - Jabba ARB - IC Waterspray (need to wire it in!) - 312mm TT brakes - Eibach Springs - Skoda Reversing sensors - Devonutopia Tuning (tm) Custom Exhaust (2 1/4" straight pipe) - Short shifter mod- 5 brake light mod - Helix Steel SMF + Organic Clutch + pressure plate - Peloquin LSD - TD stage 2 Hybrid - Washbrook remapped ECU - Uprated injectors - Cupra bushes -Poly-filled dogbone - Allard racepipe - Pirelli Dragons - Forge Rear Strutbrace - DIY SS upper boostpipe delete -Koni FSD's - elephant pipe CCV mod
Basil is offline
Old 18-06-2008, 08:06   #5
mrmo's Avatar
I think that as the bushings wear it gives a little slack in the gear stick. I shoved a nail as suggested but this still allows a little bit of movement. think it is just going to be a little bit of trial and error over the weekend to see if i can get it just right.
mrmo is offline
Old 18-06-2008, 08:42   #6
Hardcore
Basil's Avatar
Smile Re: Grinding selecting reverse
Just did mine - 10 mins work, but I cheated.
Here's Bas's quick and dirty (very dirty) adjustment procedure:
engine off/cold
1- disconnect + remove air intake tube - phillips screwdriver.
2- as you look down on the shifter above the trans you see two cables with springs on them
3- start with the left - using three fingers squeeze the collar back (it's spring-loaded) then twist to lock open. Make a mental note of where the plastic jaws end on the steel cable end.
4- move the jaws of the plastic collar towards the car rear1-2 mm shortening the cable. twist the collar and release to clamp back onto the steel cable.
5- try all the gears
6- repeat with small adjustments back and forth until all gears engage smoothly - 1-2 and R are the most fiddly...
7- spray grease on all moving parts for good measure
8- replace the PD160 air tube
I found that the left one only needed adjustment (and has done a couple of times in the past). The proper tranny adjustment lock is under the battery and is a PITA to reach without removing the battery tray as well. You don't need to remove the airbox at all to adjust.
I did this alone, but a driver testing the gearchange at the same time as you adjust the linkage would make it a snap.
(remember adjusting those old roof TV antennae's - shouting to the wife "is that better?", :lol)
HTH
Bas
Basil is offline
Old 18-06-2008, 12:49   #7
KenONeill's Avatar
Members Car: Octavia TDi110
Try these in this order:-
Adjust linkage, already covered.
Change gear oil. Do not use Silkolene as the new oil, because VAG boxes don't like it.
If neither of these have worked, replace the dogbone mount.
KenONeill is offline
Old 18-06-2008, 13:06   #8
Hardcore
Basil's Avatar
As an alternative to changing the dogbone - you could try filling the dogbone with polyurethane - see the tech guides section. It's an upgrade.
random thought-if you've ever had the console bolts loosened - check they're tight. I had probs engaging 3rd around sweeping curves as they weren't snug.
Good luck with it all.
Basil is offline
Old 18-06-2008, 13:43   #9
KenONeill's Avatar
Cheers Baz; I might have a go at that console check, cos I occasionally miss 3rd, usually on turns.
Old 18-06-2008, 14:40   #10
Hardcore
Basil's Avatar
I did my nut on trying to figure out that 3rd gear miss - then while I was having a 4WA done I asked the mechanic to check the console nuts - they were slightly loose, despite having been torqued up with threadlock. He tightened the daylights out of them, and the prob went away.....
Let us know what happens, eh?
Basil is offline
Old 18-06-2008, 19:44   #11
mrmo's Avatar
just spent an hour, thought i had it perfect, smoothly in all gears, took it for a short drive and no not quite!
i guess gear box oil next?
Why would/what is, the dog bone/help?
mrmo is offline
Old 18-06-2008, 20:13   #12
Hardcore
Basil's Avatar
neat US blurb on adjusting - VW Volkswagen GTI-VR6 List - Old Library - How-to: More on adjusting shifter linkages
dogbone mount info: http://briskoda.net/forums/technical...-guide/106368/
found some advice - if first gear grinds - shift into 3rd then first.
also see: 60 How can you tell if your synchro is REALLY shot?
HTH
Bas
Basil is offline
Old 18-06-2008, 21:50   #13
mrmo's Avatar
after reading that, i am going to be spending saturday making tiny cable adjustments.
mrmo is offline
Old 19-06-2008, 08:31   #14
KenONeill's Avatar
If it's adjusting to "ok" engine off, and out as soon as the car moves, then it's either the console (QV Basil) or the dogbone I think. The reason being that, when the car is still, you can adjust everything to line up right, but, as soon as it moves, something goes slightly out of alignment, so something mechanical must be moving funny.
Old 19-06-2008, 08:46   #15
mrmo's Avatar
Where are the console bolts? are these the ones i can see with the shift gater detached?
I am guessing looking at pictures that the dog bone is under the car? and needs tools to fit? on the basis that i have no way of lifting the car and my tool box is only good for stripping bikes. I think i am going to have to see if i can find someone to have a go.
Any idea on the time it would take? the bushes don't look too expensive but labour rates being labour rates? And as for oil, i might as well do that at the same time? do you know what spec and roughly how much?
mrmo is offline
Old 19-06-2008, 09:00   #16
KenONeill's Avatar
I presume the most relevant ones are the ones around the gaiter yes, but I've not even looked at my Haynes, with or without the car, yet.
The dogbone is a gearbox support mount, named for its shape. Again you're looking at checking manuals for more details, but it's the sort of job any local garage with a lift can do.
Similarly with gear oil; spec is basically EP 75W-90 synthetic, but as previously, don't use the Sylkolene product. Several of us have in the past, so we know that VAG boxes don't like it.
Old 19-06-2008, 09:05   #17
Hardcore
Basil's Avatar
I had a tad grinding myself - read your post and then went and adjusted my cables + lubricated them.
Far smoother now - good of you to start this post - reminded me that I had the same prob,
console bolts are the four ones directly under the the front axle. You can see them as you look straight up, lying under the car - fitting into a sort of flat winged ally+ steel effort stretching between the wheels, aka console. Kinda distinctive - a steel box with 4 bolts in it and a winged ally bit inside it.
You can squeeze under there if you're slim (not me!) or if you carefully jack up a wheel and place a proper safety stand as well. They need to be torqued to "bl**dy tight", so you dont want the jack to shift and car to fall on top of you.
Dogbone mount fits with 2 bolts into the console/under-engine. Easy to remove. When you re-fit I seem to remember that you should push the engine fwd with your hands before tightening fully, I think that's cos the engine torques its bottom rearwards under load. Could be wrong about that point....
HTH
Bas
Basil is offline
Old 19-06-2008, 09:33   #18
KenONeill's Avatar
So WTF are they called "console bolts" then? They're noplace near a console that I can see (and above the undertray on the TDis).
Old 19-06-2008, 11:01   #19
mrmo's Avatar
why would the dog bone affect me when selecting reverse, i am stationary in first, select reverse and get a crunch? Is it just the torque of the engine causing havoc?
mrmo is offline
Old 19-06-2008, 11:06   #20
KenONeill's Avatar
Ah, reverse is a different matter entirely. I once regularly drove a car there the only sure-fire way of not crunching (or sometimes just getting) reverse was to:-
1) Stop.
2) Select neutral and let the clutch up.
3) Clutch right down and select first.
4) as (2)
5) Clutch right down and select reverse.
This was to get the gear teeth on reverse stopped and correctly aligned with each other. Nothing to do with the gear change mechanism, but fresh gear oil might have helped.
Old 19-06-2008, 15:10   #21
Hardcore
Basil's Avatar
reverse is the only gear that has no synchro. Wot he said to work around it.
Basically you "borrow" a synchro'ed gear's synchro before you get into reverse.
And wot he said about using only VAG box oil - they misbehave with any other stuff (I tried summat else while "running in" at one point after I installed my LSD/ATB)...
Change back to the regular VAG longlife stuff...
HTH
Bas
Basil is offline
Old 19-06-2008, 15:34   #22
mrmo's Avatar
Thanks for your help.
So adjust gear linkages and get it as smooth as poss. Then change the oil. If i can be bothered change the dog bone, but basically it is how it will be.
mrmo is offline
Old 25-06-2008, 16:39   #23
mrmo's Avatar
gone to two garages and both have diagnosed a dying Clutch..
bend over and prepare to be shafted!
mrmo is offline
Similar Threads
Auto transmission not selecting gears Bajee Octavia I 5 09-06-2008 18:35
Driving lights (selecting and fitting) anewman Styling and Car Care 9 19-08-2007 21:27
occasional clunk selecting reverse mrmo Octavia I 8 04-05-2007 13:44
Selecting Boost Stages??? MAK99 Octavia I 20 15-03-2005 11:57
Help on selecting a PC GAFF The Tech Shed 13 15-06-2004 23:41
1 2 3 4 5 6 7
