This is a discussion on Handbrake released itself within the Octavia I forums, part of the Skoda Model Discussion Area category; I was sitting in a queue at some lights this morning on a fairly steep hill, facing downwards. I usually ...
| Midnight Mod! Join Date: Jun 2004 Location: Aotearoa - land of the long white cloud
Members Car: 2004 Octavia vRS Estate Images: 1 Thanks: 155
| Handbrake released itself I was sitting in a queue at some lights this morning on a fairly steep hill, facing downwards. I usually press the footbrake, lift the handbrake lever to lock it on then release the footbrake. I did this and was sitting there for maybe 30 seconds, daydreaming, when there was a clunk and the handbrake released itself! Fortunately I reacted automatically and stood on the brake pedal, only moving about a foot. Do I need to get something checked out or could this be a one-off weird thing? I need to be able to trust my handbrake as Wellington is pretty hilly and I often leave the car parked on slopes (in gear of course)
__________________ Corrida Red 2004 Octavia vRS Estate - It's the bestest Skoda in New Zealand! Whaia te mātauranga, whaia te māramatanga - Pursue knowledge, pursue the wisdom of knowledge www.pimpmyskoda.co.uk www.clubley.org Facebook Last edited by RobClubley; 15-08-2007 at 00:39. |
| Briskodian | Re: Handbrake released itself If in doubt I would get it checked, better a small bill for checking than a larger one for a respray or other repairs.
| 207/340 Join Date: Oct 2004 Location: Around Manchester & Cheshire
Members Car: Skoda Fabia vRS Thanks: 457
| Re: Handbrake released itself Whoops! Did the car start to move with the lever in the same position Rob? Or was it a case of it returning the usual 'off' position? Get it checked, whichever way! Steve
__________________ Wardy's Fabia vRS ![]() xenons : sunroof : cruise : OEM+ ![]() "Racing is life. Anything before or after is just waiting." - Steve McQueen "If in doubt, flat out." - Colin McRae |
| Re: Handbrake released itself It just released itself and dropped back to the off position. I'm surprised it could do that to be honest! I'll call in at my favourite German car specialist this evening ![]()
__________________ Corrida Red 2004 Octavia vRS Estate - It's the bestest Skoda in New Zealand! Whaia te mātauranga, whaia te māramatanga - Pursue knowledge, pursue the wisdom of knowledge www.pimpmyskoda.co.uk www.clubley.org Facebook |
| Briskodian | Re: Handbrake released itself I havn't seen anything like this on any of the cars with all round disks that I have had. Even a citroen BX where the handbrake was on the front disks never did this when you applied light pressure on the foot brake before applying the handbrake.
| Re: Handbrake released itself I use the handbrake quite a lot in traffic as it's mostly hilly here and I've never had a problem - I'll definitely get it checked out as I like the shape of the front end of the car ![]()
| Nuts Join Date: Nov 2006 Location: Greater Manchester
Members Car: Fabia vRS Thanks: 152
| Re: Handbrake released itself I've had this happen - but I'm sure it has been my fault. Having a lot of mechanical sympathy I too press on the brake, pull up handbrake and gently release button. And, there, I think, is the problem - i.e. it is not 'latching' properly. To remedy this you need merely follow the actions of a mother in a hurry. Rip, scrunch (wheels stop turning two seconds later). There - now you know it's latched ![]()
__________________ "Stupidity, if left untreated, is self-correcting." - Heinlein Last edited by anonymouse; 15-08-2007 at 01:04. Reason: am daft |
| Re: Handbrake released itself Treat her rough eh? ![]()
| Re: Handbrake released itself No sheep jokes please. This is a highly technical conversation ![]()
__________________ "Stupidity, if left untreated, is self-correcting." - Heinlein |
| | #10 |
| Re: Handbrake released itself Baa-humbug!
| | #11 |
| Re: Handbrake released itself Ewe know it makes sense. Do I have to ram home the point. Oh, if my explunashion doesn't fit - then, yup, get it checked out.
| | #12 | |
| Re: Handbrake released itself Quote:
I think I'll get it looked at anyway. No point taking any risks with brakes!
__________________ Corrida Red 2004 Octavia vRS Estate - It's the bestest Skoda in New Zealand! Whaia te mātauranga, whaia te māramatanga - Pursue knowledge, pursue the wisdom of knowledge www.pimpmyskoda.co.uk www.clubley.org Facebook | |
| The Following User Says Thank You to RobClubley For This Useful Post: | anonymouse (15-08-2007) |
| | #13 |
| Briskodian Join Date: Oct 2005 Location: derby/midlands
Members Car: skoda octavia 1.9tdi (110) Thanks: 0
| Re: Handbrake released itself mine has done it a time or 2 when its not properly engaged into the notches, normally its straight away though |
| | #14 |
| Briskodian Join Date: Dec 2003 Location: Coventry
Members Car: Octavia vRS Thanks: 8
| Re: Handbrake released itself Yeah same as above, I've had it once or twice when it hasn't properly engaged.
__________________ vRS Mirror polished 9*18" Mercedes Alloys, APR FMIC, ABD TIP & CAI, Powder coated inlet manifold, Jabba Re-map, Blueflame/Pipewerx exhaust, Forge DV, KW v3 coilovers, Neuspeed ARB, S3 strut braces, bonnet lifters, Autostyl rear spoiler, Milotec rear diffuser & bumper grills, side rubbing strips removed, front and rear rubbing strips smoothed and colour coded, scuttle pannel colour coded, chrome grill colour coded, mk2 vRS badge, de-locked, tints, mk4 aero wipers. |
| | #15 |
| Re: Handbrake released itself Could be the brake discs cooling down, especially if you have just driven down a steep hill and had to use the brakes a lot. As they cool, the discs contract, thus eventually friction between pad and disc is lost. This is quiet a common where the rear disc pads are used to hold the car on the handbrake, its for this reason that some manufactures fit brake shoes into the hub of their rear disc brakes to hold the car. My old XJ40, and the Boxster had rear discs for normal braking and shoes for the handbrake.
| | #16 |
Members Car: Octavia TDi110 Thanks: 65
| Re: Handbrake released itself I disagree with a fair bit of the above. From what Rob says, the HB actually moved down several notches by itself, and IME that only happens if you use a "lazy handbrake" and actually wear out the locking pawl! |
| | #17 |
Members Car: Ford Escort 1.6LX + Fab Estate Thanks: 46
| Re: Handbrake released itself I've had cars with 160k miles on the clock that were always 'lazy handbraked' to pull up the handbrake, never had trouble with it wearing out. And if it does, it's generally a pretty easy bracket to replace ![]()
__________________ WW --->> Project Journal (pic links in first post there)Lummox'/Ross thread on Unit18 Automotive progress on my car: here |
| | #18 |
| Re: Handbrake released itself TBF there were suggestions of a missing heat treatment being involved, but the point still stands I think. |
| | #19 |
| Re: Handbrake released itself Yep ![]()
| | #20 |
| Briskodian | Re: Handbrake released itself |
| | #21 |
| Briskodian Join Date: Aug 2007 Location: Lincolnshire
Members Car: FABIA 1.9TDI ELEGANCE ESTATE Thanks: 4
| Re: Handbrake released itself Ensure that the teeth on the handbrake ratchet are not worn out because this would cause the problem. Did the handbrake ratchet properly engage when you pulled it up? If it had not engaged then it will slip particularly on an incline. If in doubt get the car checked over. It should have disk brakes at the rear so there should not be any problems there as they are extremely reliable compared to drum brakes. Steve |
| | #22 |
| Briskodian Join Date: Jan 2007 Location: Leeds
Members Car: 1994 Skoda Favorit GLXIe Estate Images: 1 Thanks: 1,120
| Re: Handbrake released itself I've not pressed the button on my handbrake ever since I did so and the pivot pin fell out of the mechanism leading to the centre button coming free and the handbrake not holding, cue nearly an hour of wiggling and struggling to push it back in I think it's only held in by the pressure of it pivoting against the ratchet mechanism, so I added some duct tape. I suppose older handbrakes are easier to fiddle with though. Especially when it's only covered with an easily removable plastic trim. |
