This is a discussion on Head gasket within the Octavia I forums, part of the Skoda Model Discussion Area category; Hi all. Octavia 110 tdi, lost water a couple of times from the expansion tank not sure if the presure ...
| Briskodian | Hi all. Octavia 110 tdi, lost water a couple of times from the expansion tank not sure if the presure cap is falty or the head gaskets gone . The water in the tank has a black somthing on the top, but not oily more of a powdery type of thing. With the cap off if you rev it a bit the water will rise and a few bubbles come up not sure if its the gasket or trapped air. If you put the cap on the hoses don't pressurise like you would expect if it was the gasket (unless very slight leak).If you push it on the motorway after a while the temp will rise drop and lose water out of tank only. Any ideas anyone. Cheers |
| Briskodian Join Date: Mar 2007 Location: Greece
Members Car: OCTAVIA 1.6 TOUR Thanks: 0
| Re: Head gasket replace the presure cap it is the easy and cheap way to start troubleshoting. |
| Need more power Join Date: Feb 2007 Location: Driffield, Good old yorkshire
Members Car: octavia VRS Thanks: 54
| Re: Head gasket Any white gunk on the oil filler cap?
__________________ Regards Martin Turbo back blueflame exhaust |
| Briskodian Join Date: Oct 2007 Location: Birmingham
Members Car: Octavia Elegance 1.9tdi Estate Thanks: 5
| Re: Head gasket or the dipstick?
__________________ Ok I know I'm old, I've just found out that they have discontinued my blood group! |
| Briskodian | Re: Head gasket Oil is fine, could the black floaty stuff in the water be from the exhaust gas, like i said its not oil but i suppose it could be carbon deposits, if you run it to temp with cap off after a while when you rev it will rise and come out the tank, with the cap on it will come out the tank if you drive it hard. If it is the head gasket are they much of a pain to do. |
| Briskodian Join Date: Aug 2006 Location: Liverpool
Members Car: Octavia vRS Thanks: 12
| Re: Head gasket When was the waterpump last done? They have a habit of going Pete Tong if not replaced at required intervals.
__________________ 2001 Rally Red Octavia vRS...remap complete Whiteline rear ARB, Superpro dogbone bush - 225/45/17 Goodyear Eagle F1 Aysmmetrics and lots of V-Power!Smiles all 'round |
| Briskodian | Re: Head gasket Have not replaced waterpump but would it not overheat if the pump was faulty? also took it steady today (not above 2500 rpm on motorway & round town) and it has'nt lost any water and the black stuff has gone and the header tank is clean inside ![]() |
Members Car: Octavia TDi110 Thanks: 65
| Re: Head gasket Sounds a bit like the pressure cap to me (at least as a first stop). |
| Head Gasket | billyuk | Octavia II | 1 | 14-09-2007 17:03 |
| Possible Head Gasket Problem?? | Amr Emarah | Favorit, Felicia, Fun and Forman | 2 | 12-09-2007 22:45 |
| 2.0TDi Head Gasket | scrak | Octavia II | 24 | 22-06-2007 16:35 |
| Head Gasket Horror! | skodielove | Favorit, Felicia, Fun and Forman | 37 | 25-04-2007 22:13 |
| Head gasket failure? | Johnhowell | Fabia I | 20 | 21-11-2006 18:36 |
