This is a discussion on Headlight bulb change how to. within the Octavia I forums, part of the Skoda Model Discussion Area category; Hi, Ive tried searcing but cannot find a bulb change howto for the octy mark 1, non xenon. Ive found ...
| Briskodian Join Date: Jun 2007 Location: Notts
Members Car: Octavia VRS Thanks: 1
| Headlight bulb change how to. Hi, Ive tried searcing but cannot find a bulb change howto for the octy mark 1, non xenon. Ive found a howto for every other skoda model though! Ive ordered 2 pairs of the h4 philips xtrmem +80% ones to replace the dire standard bulbs, should be here tomorrow, also got some free bluevision sidelights, are these anygood. Was going to get the slightly cheaper osram +90% but couldnt find any info about them being safe for plastic lenses so plumped for the recommended philips ones. I will take some before after pics too as I drive to work @ 5am Cheers |
| Briskodian Join Date: Oct 2004 Location: Cleveland
Members Car: OCTAVIA vRS (53 reg.) Thanks: 0
| Re: Headlight bulb change how to. To access the bulbs on my 53 plate octy vrs, a rectangular black plastic cover on the back of each headlight needs to be removed. The cover is held in place by a single wire securing clip. The O/S headlight is OK to do, but the N/S is awkward because of the battery. Possibly just as easy to pop the headlight out and do on a bench. Its only held in by 4 bolts (one is behind the indicator). If you do remove the headlight, be sure to protect the paintwork on the bumper with some masking tape first. Also try to avoid turning the headlight upside down ( ie; glass side down) otherwise you may find you get pieces of debris trapped between the reflector and glass. Hope this helps bill |
| The Following User Says Thank You to vrs180 For This Useful Post: | thebloyn (15-10-2007) |
| Re: Headlight bulb change how to. Cheers Bill, Id heard it was easy but Ive a habit of messing things up, will see how to goes when the bulbs arrive |
| Briskodian Join Date: Jun 2007 Location: Norwich
Members Car: Octy vRS Thanks: 5
| Re: Headlight bulb change how to. Its a piece of cake to do, just make sure you don't touch the bulbs with your fingers. As for the bulbs themselves... I was a bit disappointed, they didn't seem any better than the Philips Vision Plus +50% bulbs that I've used in the past, despite being £10 a set more expensive ![]()
__________________ ![]() |
| New Octavia - Headlight Bulb Change | andy2407 | Technical Guides | 25 | 27-10-2008 14:44 |
| Headlight bulb replacement | Ratt | Maintenance & Performance | 19 | 05-09-2008 17:43 |
| Another Bulb Change Query! (Granted, not as important as a headlight!) | numskull | Superb | 7 | 11-08-2007 14:03 |
| Help headlight bulb | Glider | Fabia I | 2 | 29-12-2006 17:31 |
| Headlight Bulb Failures | mannyo | Maintenance & Performance | 6 | 01-04-2004 18:03 |
