This is a discussion on Heated rear screen......... within the Octavia I forums, part of the Skoda Model Discussion Area category; problem with heated rear screen, when the button is pressed the light comes on but the rear window doesn't clear, ...
| Briskodian Join Date: Oct 2007 Location: Norwich
Members Car: Skoda Octavia Laurin & Klement 2001(X) Thanks: 5
| Heated rear screen......... problem with heated rear screen, when the button is pressed the light comes on but the rear window doesn't clear, i've had it on for about 10 minutes with no effect. the car is 2001 lauren & klement, anyone got any ideas? i'll check the fuses tomorrow in daylight, will this fuse be located under the bonnet or in the car? cheers for the help, Shaun. |
| Briskodian Join Date: Aug 2006 Location: Watford
Members Car: Mondeo 2.2TDCI Thanks: 21
| Re: Heated rear screen......... Mine is doing this on my Octy VRS. Going to try and look at it over the weekend!
__________________ Octavia VRs ***SOLD*** The futures somkey! The futures diesel ![]() |
Members Car: Skoda Fabia Mongrel Images: 5 Thanks: 75
| Re: Heated rear screen......... Can you hear a fairly distinct click when you push it? (may need the engine off but ignition on to hear it properly). If you're hearing this then it's probably one of the earthing points in the bootlid. Might have rattled loose if you slammed the boot a bit? I managed to wedge mine back in and secure it, and now I have a working demister. Was a relatively easy job. Removing and refitting the trim took longer than securing the earth point back. ![]()
__________________ Jason - Only a Skoda. Custom Fabia Bonnet Lifter Kits - £45! Click Me. Cheesy bonnet lifter video to "raise me up" http://www.youtube.com/watch?v=hMnGECEi5Oc See the mongrel's 260bhp Dyno Video! |
| Re: Heated rear screen......... i'll have a look into that tomorrow too, cheers. |
| Re: Heated rear screen......... checked the fuse that was fine. i've just had the trim off, where abouts is it earthed? cheers. |
| Briskodian | Re: Heated rear screen......... Mine had this problem when it was still under warranty (6 years ago now) and they ended up replacing the switch in the dash. No problems since. |
| Heated rear screen issue | devonutopia | Fabia I | 8 | 31-10-2008 17:46 |
| Heated rear screen | Timo | Octavia I | 2 | 20-11-2006 19:30 |
| Heated Rear Screen | cjh82 | Octavia I | 2 | 26-10-2006 14:55 |
| Heated rear window | Ali C | Octavia I | 2 | 24-02-2006 00:15 |
| Can you retro fit a heated front screen | fireman | Fabia I | 17 | 03-01-2006 08:34 |
