This is a discussion on heated wing mirrors within the Octavia I forums, part of the Skoda Model Discussion Area category; Maybe a silly question, but I have a 2001 Octy Elegance and it has the switch on the drivers door ...
Members Car: Octavia 2001, 110TDi Elegance estate Thanks: 0
| heated wing mirrors Maybe a silly question, but I have a 2001 Octy Elegance and it has the switch on the drivers door for for heated mirrors, but I am not sure it does anything... should I feel the glass get warm if I turn it on? How can I check it does work? M |
| Briskodian Join Date: Sep 2004 Location: Sheffield UK
Members Car: Octavia 1.8 20V Turbo Laurin & Klement Thanks: 5
| Re: heated wing mirrors Well when my L&K heated mirrors have been on recently in the frosty cold morning you can see the ice/ frost melting and giving off steam into the air - i belive that you have to have the rear heated screen on for the wing mirror heaters to function IIRC. HTH, Lee
__________________ What is: Octavia vRS... Black Magic yet again... with plenty planned ![]() What was (May she RIP): Blk Magic Octy (Not quite a VRS) L&K,Climate,Heated leather,Cruise,Xenons, MODS(so far): Custom Code Phase II JBS-Forge-007P DV, Forge/Samco TIP, 18" Ace 205's, ABD/JBS CAI (*Wooosh), Audi TT 312mm Brakes |
| | #3 | |
Members Car: Fiat Panda Thanks: 15
| Re: heated wing mirrors Quote:
Saying that, the mirrors on my Fabia seemed quite pathetic compared to other cars with heated mirrors I've owned, so maybe this is a Skoda/VW trait - my dealer told me they were working fine.... Chris
| | #4 | |
| Briskodian Join Date: Jun 2005 Location: Canterbury, Kent
| Re: heated wing mirrors I too have a switch for the heated mirrors, but it's the same one as turns on the rear screen heater - they work as one. IIRC, the door-mounted switch for the electric wing mirrors (I presume that's the one you're referring to) has to be in the central position for the mirror heating elements to work.= (dunno why). Give it a whirl! |
| | #6 | |
| Re: heated wing mirrors Thy work in the central position as if you dont want them on leave the switch on either left or right. |
| Briskodian Join Date: Dec 2005 Location: south east
Members Car: Fabia Vrs 2004 "54" Standard Thanks: 0
| Re: heated wing mirrors If they still dont work, carefully prize the glass off, on the back should be 2 small connecters plugged into the glass, it could just be someone has done a repair and not plugged them back in! If they are still on there, check for a live feed when its all turned on, with a test light. Quick and easy when you know how |
| Briskodian Join Date: Nov 2005 Location: Belgium
Members Car: Octavia Combi SLX TDI Thanks: 0
| Re: heated wing mirrors The description above doesn't match my Octavia... The mirror switch has three positions: -bottom: R only (my vehicle is left hand driven) -middle: L+R -top: heater on but only if rear window heater is on Maybe that's why it seems they don't work. Good luck!
__________________ Regards, Ernst |
| | #10 | |
| Heated glass for Octavia wing mirror | tonnoir | Octavia I | 10 | 17-11-2005 14:32 |
| new octavia wing mirrors | mcbunny | Fabia I | 0 | 30-11-2004 00:07 |
| Fabia Wing Mirrors? | FABDAZ | Maintenance & Performance | 12 | 17-09-2004 16:20 |
| New Passat wing mirrors with indicators | andy_ccr | Styling and Car Care | 0 | 27-04-2004 16:43 |
| Fabia heated mirrors | ScoobyChris | Maintenance & Performance | 14 | 20-03-2004 13:05 |
