This is a discussion on Heating control Illumination within the Octavia I forums, part of the Skoda Model Discussion Area category; Hi I have an octavia with rotary heating controls (not the climatronic) and have recently noticed they don't light up ...
| Briskodian Join Date: Jul 2005 Location: midlands
Members Car: Octavia 1.4 2001 Thanks: 0
| Heating control Illumination Hi I have an octavia with rotary heating controls (not the climatronic) and have recently noticed they don't light up with the rest of the interior lighting at night- is this because they dont have any backlighting, or because it's broken... in which case does anyone know how I go about fixing it? Many thanks, rob |
| Briskodian | Re: Heating control Illumination Hi Yes they do have backing lights. Was a common problem when I worked at the dealers. You need to replace the whole of the heater pannel as they are LED`s The heater will still work ok So could be worth leaving it? Dont know depends how much you use them in the dark I suppose. Sarah |
| Briskodian Join Date: Dec 2005 Location: south east
Members Car: Fabia Vrs 2004 "54" Standard Thanks: 0
| Re: Heating control Illumination some of the octavias do have tiny bulbs behind the heater controlls, you unclip the surround and if you are carefull with some small long nose pliers, they pull out, ive changed a few. Mainly on taxis! |
| Bored! Join Date: Apr 2005 Location: Macclesfield - Cheshire
Members Car: Octavia VRS Thanks: 30
| Re: Heating control Illumination I've the same problem on mine.....Try puling the heater switch out a touch,worked on mine. |
| ECUless | Re: Heating control Illumination Sarah I think that you are getting confused with Climatronic. In the non Climatronic there is only one illumination bulb which is situated behind the control for the fan. Pull the fan control kn0b off, usually a pair of mole grips with some cardboard padding to prevent damage, pull the bulb out and replace. Can use long nodse pliers very carefully, or a bit of plastic/rubber tube over the bulb. |
| Re: Heating control Illumination Thanks for this- just replaced the bulb, works a treat! Cheers |
| Introduction to the NEW Octavia | ColinD | Octavia II | 2 | 22-02-2007 20:09 |
| heater control illumination. | HO99Y | Octavia I | 3 | 29-03-2006 08:35 |
| Illumination Control | 1995LXiSkoda | ICE, Security and Insurance | 1 | 30-11-2005 23:34 |
| Introduction to the Superb | ColinD | Skoda History | 0 | 03-06-2004 11:21 |
| New Octavia In Detail | ColinD | General Car Chat | 0 | 22-04-2004 12:18 |
